Insulation Question For Vaulted Home - Insulation - DIY Chatroom Home Improvement Forum
Old 08-21-2012, 08:32 PM   #1
Insulation question for vaulted home
I have a manufactured double wide house with vaulted ceilings I've measured the inside / outside pitch. The inside pitch is 12/2 and the outside pitch is 12/4. Since the house is a double wide i measured half of the width which is 12.5 feet. I've done some calculations and at 12.5ft the outside is 150/50 and the inside is 150/25. That would leave me with roughly 25inches of room towards the top of the house correct?
I have soffit vents going around the entire house. I do not know what i currently have for insulation in the house. I have no way to check the insulation myself. I had an energy audit and the guy said he figured it was R-19 on the roof. I live in WI and that is very low. If i were to add insulation what would be the best approach?
Going in from the roof every few feet, adding insulation, and then repairing the shingles??... Is there any way i can check the level of insulation that i would currently have in the roof?? The only way i thought would be to cut a hole from the garage and inspect it from there. My house has ridge vents but i'm not sure if i could peel them up to check?...
I'm trying to make my house as energy efficient as possible. I've already air sealed it and now i wanna see if i need insulation / how much i could add.
Questions
How much room do i need to allow the roof to breath? If i were to add insulation would i need 1 inch of room between the insulation and the top, 2 inches... 3?...
Talgonadia is offline   Reply With Quote
Old 08-21-2012, 11:06 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,786
If the pitch is steep, an unimpeded 1" can do it most times. 2" is plenty and usually allows for some leeway.
Old 08-22-2012, 12:17 AM   #3
Is my pitch considered steep? I figure once I find out how much insulation I have ill then determine if I should consult somebody who would install it
Old 08-22-2012, 07:06 AM   #4
2-4:12 is not considered steep.
New home construction.. Small attic minimal insulation Robert95z Insulation 9 06-12-2012 01:27 AM
Insulation question Branden Building & Construction 1 08-03-2010 02:02 PM
mobile home service to bond or not to bond rikmac Electrical 35 03-17-2010 04:47 PM
Same old Question basement Insulation advice rp92285 Building & Construction 2 02-05-2010 12:01 PM
Basement Insulation question tophercole Building & Construction 0 11-19-2009 10:01 AM
