Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 11-24-2012, 09:54 PM   #1
Insulation question
Hi, everyone - first post for me so I'll try to make it quick! We are moving to a new home - attic has a 3/4" plywood floor with (I assume but have not been able to check) insulation underneath. Inspector gave it a roughly R24 rating. We would like to add to this. From a moisture standpoint, can I just roll out some R30-something insulation right over the plywood or would the plywood need to be removed? Paper-faced for a vapor barrier or unfaced? Thanks in advance!
tjniemann is offline   Reply With Quote
Old 11-24-2012, 10:36 PM   #2
joed's Avatar
Insulation question
right over the plywood should be fine. The vapour barrier needs to be at the ceiling level. Unfaced. You do not want two vapour barriers.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 11-25-2012, 12:21 AM   #3
Insulation question
Do any air sealing you can while anything might be exposed; around elect wires, pipes, ducts, etc. Spray foam and/or caulking should work well. Cellulose blown over the whole area will do much better than FG batts.
Old 11-26-2012, 08:06 PM   #4
Insulation question
Appreciate the replies. Specifically, why would the blown work better than the rolled?
Old 11-26-2012, 08:12 PM   #5
Insulation question
blown cellulose will fill all voids and will slow down air movement better than fg. it also "crusts over" to further limit air movement through it.
Old 11-27-2012, 10:05 AM   #6
ink
DIY Enthusiast
ink's Avatar
Insulation question
Where do you live? Local climate will change your vapor barrier needs.
inK
Hammer in Hand, Dad on Speed Dial
ink is offline   Reply With Quote
The Following User Says Thank You to ink For This Useful Post:
Gary in WA (11-27-2012)
Old 11-28-2012, 06:57 PM   #7
Moderator
Insulation question
The plywood is a vapor retarder. Any (1/8") gaps under the plywood will effective allow moving air to rob you of insulation R-value added on top the sheathing. Still air has R-1 for 1-4". You may grow mold under the sheathing, check annually, with insulation on top.
Gary
Clothes taking longer to dry?
Fixing multiple attic electrical issues before blowing in insulation darlingm Electrical 11 11-19-2011 10:19 AM
Another cape insulation question exiledgator Building & Construction 21 10-14-2011 09:42 PM
Garage insulation question trojanman1 Building & Construction 7 09-16-2009 03:51 PM
rafter insulation question Jeremy Hillary Boob, PhD Building & Construction 7 08-02-2009 09:19 AM
Insulation Question skavang13 Building & Construction 3 11-16-2008 06:08 PM
