-   Insulation (http://www.diychatroom.com/f103/)
-   -   Insulation question (http://www.diychatroom.com/f103/insulation-question-164585/)
tjniemann 11-24-2012 09:54 PM
Insulation question
Hi, everyone - first post for me so I'll try to make it quick! We are moving to a new home - attic has a 3/4" plywood floor with (I assume but have not been able to check) insulation underneath. Inspector gave it a roughly R24 rating. We would like to add to this. From a moisture standpoint, can I just roll out some R30-something insulation right over the plywood or would the plywood need to be removed? Paper-faced for a vapor barrier or unfaced? Thanks in advance!
joed 11-24-2012 10:36 PM
right over the plywood should be fine. The vapour barrier needs to be at the ceiling level. Unfaced. You do not want two vapour barriers.
jklingel 11-25-2012 12:21 AM
Do any air sealing you can while anything might be exposed; around elect wires, pipes, ducts, etc. Spray foam and/or caulking should work well. Cellulose blown over the whole area will do much better than FG batts.
tjniemann 11-26-2012 08:06 PM
Appreciate the replies. Specifically, why would the blown work better than the rolled?
jklingel 11-26-2012 08:12 PM
blown cellulose will fill all voids and will slow down air movement better than fg. it also "crusts over" to further limit air movement through it.
ink 11-27-2012 10:05 AM
Where do you live? Local climate will change your vapor barrier needs.
Gary in WA 11-28-2012 06:57 PM
The plywood is a vapor retarder. Any (1/8") gaps under the plywood will effective allow moving air to rob you of insulation R-value added on top the sheathing. Still air has R-1 for 1-4". You may grow mold under the sheathing, check annually, with insulation on top.
Gary
