Insulation Quandary (knee Walls With Photo) - Insulation - DIY Chatroom Home Improvement Forum
Old 01-06-2013, 02:37 PM   #1
Insulation quandary (knee walls with photo)
I am having trouble piecing together my insulation plan for a 2nd story renovation (2 story cape cod).
Existing:
2x4 exterior and knee walls
2x6 rafters
Some extremely inefficient insulation from 1952.
My plan
1) 2x6 glued and screwed to face of rafters to increase cavity to 11".
2) R30 batt insulation for a depth of 9.5" with ventilation channels under roof boards
3) 2x4 glued and screwed to exterior and knee wall framing.
4) R21 batt insulation (5.5" depth batts)
5) Use 2" DOW Super Tuff blue/pink foam board on framing facing interior of room and then tuck-taping and Great Stuff foam to provide a vapor barrier.
6) 1/2" drywall for fire protection.
7) Batt insulation will run in joist cavity from vent channels (at soffit vents) to approximately 6 inches under the subfloor. (I might use pink foam board block caulk/foamed at interior end of joist cavity to block air flow between ).
8) There are 2 rooms on either side of the stair landing on the 2nd floor. The stair case is finished living space and the 2 rooms were designed so that the home-owner could finish in the future (which is now me). The first side we are planning to finish will be the master bedroom. The other side will hopefully be a master bath down the road. The bedroom side will be connected to our gas HVAC system. We had an HVAC guy inspect our system and said the existing system will adequately handle the additional finished attic space.
Some assumptions:
-The area behind the knee wall will be unconditioned and will vent from existing soffits to existing ridge vent.
My questions
1) Do I have to worry that the backside of the foam board will not have any fire protection other than approx 5" of batt insulation?
2) Do I have any other vapor barrier issues?
3) If the weight of added 2x6 framing on the existing rafters is too much, I could reduce it to 2x4 (or 2x3 if really needed).
4) Am I missing anything here? Or am I oversimplifying this?
Am I on the right track? Thanks for reading my wordy post!
kevabar is offline   Reply With Quote
Old 01-06-2013, 04:13 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,884
Where is the home?
Ever consider just spray foaming the whole thing and make it a hot roof deck? While it might be a bit more expensive, the impact on ceiling height and hassle would be greatly reduced.
Old 01-06-2013, 04:24 PM   #3
I am in south Jersey directly east of Philly; zone 4. I do not want to spray foam because I merely do not have the funds for that. Plus, I do not want it directly on the decking.
Old 01-09-2013, 12:37 AM   #4
Registered User
Rewards Points: 5,216
1 plywood gussets with nails
2 use rigid f.b.against f.b. spacer strips for no convective heat loss at the baffles; http://www.buildingscience.com/docum...n-roof-venting
5 f.b. on the attic side with/without ignition barrier, check locally; http://dow-styrofoam.custhelp.com/ap...KkNueDl5R2s%3D
4.4.1-2: http://www.icc-es.org/reports/pdf_fi...S/ESR-2670.pdf
6 ADA drywall; http://www.buildingscience.com/docum...wall-approach/
Gary
PS caulk the sill plate/floor joint.
Old 01-10-2013, 04:32 PM   #5
Thanks for the input, guys! that is some great info.
Old 01-10-2013, 11:01 PM   #6
Registered User
You're welcome, that's why we are here!
Gary
Insulation for walls in South Florida Amberlily Insulation 3 08-09-2012 03:52 PM
Basement Exterior Above Grade Insulation purpasadu Building & Construction 6 02-28-2012 05:42 PM
Newbie questions on refinishing walkup attic with knee walls FileOpen Insulation 2 11-20-2011 12:31 AM
Zone 6 - Wall Insulation: building out 2x4 walls DoItMyselfToo Building & Construction 15 05-06-2011 09:36 AM
adding insulation exterior walls, is it worth it? justin76 Insulation 9 03-07-2011 09:57 PM
