Insulation - Paper Faced Vs Plastic Wraped - Insulation - DIY Chatroom Home Improvement Forum
Old 12-29-2012, 04:42 PM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 1,826
Insulation - Paper Faced vs Plastic Wraped
I can get 2 basic types of fiberglass insulation at HD and Lowes....
Paper Faced & Plastic Wraped (the whole bat is covered with plastic)
In the attic I typically used the plastic wraped stuff since it was easier to keep clean.
Note....I don't live in one of those obscenly cold places.....right now we are having a cold snap....it got down to 42 last night.
I have 3 areas to insulate....walls (which will have stucco on the outside), vaulted ceilings and 2nd floor floor joists....(I'm assuming the vapor barrier would go down)
I'm so of inclined to think that the plastic wraped stuff would work better in the vaulted ceiling...
Guidlines?
Old 12-29-2012, 05:16 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,760
I would go with the unfaced and cover it with Tyvek if you want to keep it from being friable.
The poly stuff is not really indicated in any capacity for your climate zone.
Old 01-02-2013, 02:00 AM   #3
Rewards Points: 1,092
"...I don't live in one of those obscenly cold places..." Hey. That's getting personal. Can you get Roxul insulation where you are, down there in Notsocoldville? greenbuildingadvisor.com has a good blog on 'how to insulate a cathedral ceiling', among other things. it may be worth checking over there, too.
Old 01-02-2013, 09:30 AM   #4
JOATMON
ddawg16's Avatar
Thanks for the link jk.......
I rode my m/c to work today.....man, it was cold.....45 deg
Negative on the Roxul....the only things I've seen are what the big box stores carry....pink...I do have some mineral wool at work....and was going to use that in a couple of places where I need to dampen sound as well....
My poor sons new bedroom is going to be pipe central.....all of the upstairs master bath plumbing goes through the ceiling and wall of his bedroom.
Old 01-02-2013, 11:09 AM   #5
Roxul is just a brand name.
Roxul is stone wool. The Big Box guys here have it.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Air barrier moisture barrier ? Faced vs unfaced insulation ? Wind82 Building & Construction 6 03-02-2012 12:00 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
faced or unfaced insulation wiggs Building & Construction 5 04-19-2006 05:50 AM
