Insulation Options For 2x3 Walls? - Insulation - DIY Chatroom Home Improvement Forum
Old 02-08-2012, 09:31 PM   #1
insulation options for 2x3 walls?
My home is comprised of a 70's single-wide that has evolved into a 1600sqft house with a pitched roof.
I'm taking down some of the original interior paneling and replacing with drywall - about 18' of wall. Seems like a good time to upgrade the insulation and vapour barrier. The catch is the walls are framed in 2x3, and I don't see my preferred Roxul in that thickness
Any suggestions for insulating? BTW, this is the pacific northwest...
u2slow is offline   Reply With Quote
Old 02-08-2012, 09:48 PM   #2
if its just straight walls can you fur the wall out 1-1/2 inches and then insulate? that would give you 4 inches
Old 02-08-2012, 10:02 PM   #3
That's a little further than I want to go. I'm actually only redoing my woodstove alcove, but I'm getting carried away already.
Old 02-08-2012, 10:10 PM   #4
you might check into the spray foam. i know it has a higher R value per inch than fiberglass.
Old 02-09-2012, 11:08 PM   #5
Rewards Points: 1,092
can you get along w/ adding 1x2's to the 2x3's and calling it good nuff? i would bet that Roxul compressed a tad is still better than fg batts. i'd also check on that vapor barrier. i really doubt that kentucky needs one; air seal real well, though. usually, vb's are reserved for zones 7 and 8; COLD places. read on buildingscience.com about them.
adding insulation exterior walls, is it worth it? justin76 Insulation 9 03-07-2011 08:57 PM
Finishing Basement Walls, Inside Perimeter Drains, and Moisture, Oh My BSponz1 Building & Construction 1 02-08-2011 01:20 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Loose Fill Insulation in walls HooKooDooKu Building & Construction 2 01-18-2010 08:03 PM
Furring out walls for insulation? ddave23 Building & Construction 2 10-12-2009 03:14 PM
