Is Insulation Needed? - Insulation - DIY Chatroom Home Improvement Forum
Old 04-19-2013, 11:30 PM   #1
Rewards Points: 154
Is insulation needed?
I removed the soffit from the cantilevered portion of my house and noticed there is no insulation. It forms part of the floor to an upper bedroom. Should I install insulation before installing new plywood?
Is insulation needed?-img_9229.jpg   Is insulation needed?-img_9230.jpg   Is insulation needed?-img_9231.jpg
ovahimba is offline   Reply With Quote
Old 04-20-2013, 12:11 AM   #2
GBrackins's Avatar
Rewards Points: 2,108
well always remember one of the laws of physics heat moves to cooler areas. You may not get harsh winter in San Fran but I'm sure you have hot summers. what do you think?
you can locate San Fran on this map to determine your climate zone. Look like 3C to me. Then go to Table 402.1.1 to determine your insulation requirements. These are found in the 2009 International Energy Conservation Code. A call to your local building department will confirm these values.
Hope this helps! Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
mae-ling (04-20-2013)
Old 04-20-2013, 12:27 AM   #3
Always learning...
fetzer85's Avatar
Rewards Points: 262
Heck yeah - otherwise those hot days will be radiating heat up through that floor with very little resistance.
fetzer85 is offline   Reply With Quote
Old 04-20-2013, 02:49 PM   #4
Rewards Points: 154
Thanks for the replies. I figured adding insulation wouldn't hurt and it would likely stablize temperatures in the house, hot or cold. The weather is pretty mild here but we do get a lot of wind blowing over those surfaces.
Old 04-20-2013, 03:06 PM   #5
Registered User
Rewards Points: 5,520
http://www.buildingscience.com/docum...n-crawlspaces/
Gary
Old 04-20-2013, 08:35 PM   #6
Rewards Points: 154
Thanks for the article. That gives me something to think about. An extension of my question would have been, do you insulate under floors.
Old 04-20-2013, 10:48 PM   #7
Registered User
You're welcome. Add cavity insulation and replace the 3/4" wood furring strips with rigid f.b., caulking/taping the joints/perimeter. Why heat/cool the outdoors; http://www.conservationtechnology.co...issionPathways
Gary
Old 04-21-2013, 12:40 AM   #8
Rewards Points: 626
The coldest winter I have had was a summer in San Francisco.
Nailbags is offline   Reply With Quote
Yes, Another Basement Insulation Question Beepster Insulation 7 11-30-2011 06:30 PM
Fixing multiple attic electrical issues before blowing in insulation darlingm Electrical 11 11-19-2011 09:19 AM
2x4 Exterior Wall Insulation stubits Building & Construction 4 03-19-2009 07:03 AM
CanLites needed in Insulation addition? i009981 Building & Construction 4 12-13-2007 09:26 PM
attic insulation question dderolph Building & Construction 10 11-03-2007 05:21 PM
