Insulation To Make Fake Rockwall? - Insulation - DIY Chatroom Home Improvement Forum
Old 01-12-2012, 11:10 PM   #1
Insulation to make fake rockwall?
Hi, all. First post.
Can any kind of spray-on insulation be used to make fake rock-wall, like what you see at amusement parks? (I don't care how the surface feels.) I have a large living room that needs to be insulated, and, at the same time, I'd like to theme it like some kind of indoor cave.
Dario D. is offline   Reply With Quote
Old 01-12-2012, 11:16 PM   #2
Rewards Points: 12,830
Just insulate the wall and use faux stone.
The fake rocks your thinking of were done with wire screen forms or strofoam with shot cret or chipped fiberglass shot from a special gun to cover them, Not something you would want to be doing inside of a house.
Old 01-12-2012, 11:35 PM   #3
Thanks. Is faux stone cheap? I forgot to specify that I'm trying to do this as close to free as possible, hence trying to do the insulation and rockwall together. If reasonable. (The room NEEDS insulation, but doesn't NEED rockwall. However, insulating the room would require redoing the walls entirely... so, it would be awesome if we could avoid ALL construction by just walking in there, spraying, then painting on the rockwall.) It's my studio, and nothing would be more awesome than turning it into a Jurassic Park facility. :D
Old 01-12-2012, 11:47 PM   #4
Cheap, not going to happen.
Old 01-15-2012, 10:43 PM   #5
Meaning spray insulation can't be painted to look like rockwall, so I would have to use "real" rockwall?
Old 06-13-2012, 10:07 PM   #6
*poke's thread*
Old 06-13-2012, 11:34 PM   #7
Rewards Points: 33
Roxul Rocks
Take a look at Roxul's RHT rock wool. If you can find a supplier, it's inexpensive relative to their other products. It comes in several thicknesses. Many have used it for inexpensive acoustic baffles. Then, integrate it with a chicken wire backing on random stand-offs to give it some rock surface topology.
I haven't yet begun to experiment with coatings, but you can form the material in interesting, organic ways. You can also design framing that would allow it to be hung, yet easily removed or reorganized for a fresh look.
Also, you might want to build some mobile walls as room separators. I leave the details to you.
Plz post pictures if you go down this path.
Lascaux is offline   Reply With Quote
Old 06-18-2012, 04:24 AM   #8
Thanks. That stuff looks good.
I'll post some pics if I remember about this thread around that time.
Made My Own Inexpensive Wood Garage Carriage Doors iffy Project Showcase 4 03-31-2012 03:07 PM
Yes, Another Basement Insulation Question Beepster Insulation 7 11-30-2011 07:30 PM
Help with complicated insulation project in attic OhmZoned Insulation 12 11-19-2011 09:49 AM
How hard to install insulation yourself? techprincesse Building & Construction 26 10-17-2009 10:57 AM
