#1 |
Insulation issue?We've recently moved to our new townhouse in MA, and it is a second month in a row we're shocked by our electricity bills. We have electric heat pump, it almost never operatres in aux mode (with electric strips), but our bills are close to $700/month (4500kWh). Essentially, to maintain 68F inside temperature, our heat pump has to work almost non-stop, though outside temperature is 32F(night)-40F(day). When heater is off, the temperature drops pretty quickly. |
#2 |
Insulation issue?
http://www.energystar.gov/index.cfm?...sulation_table
Cheap contractor grade aluminum windows and doors may not have a thermal break built into the frames so all the cold or heat just transfers into the home. Sliders are always a great big air leak waiting to happen. Consider buy some of those heat shrink plastic window covers, add foam seals to the outlets and switches. Air seal the attic, which means using expanding foam to seal any place the wiring plumbing, or ceiling fixtures were ran. |
#3 |
Insulation issue?
In addition to Joe's suggestions, I would start with your attic insulation. See how much is up there. Adding blown in insulation is relatively inexpensive.
#4 |
Insulation issue?
If you buy at least 10 bags Lowes or HD will let you use there blower for free.
#5 |
Windows & Remodeling
Insulation issue?
Thermally broken or not, aluminum windows just aren't a good choice in colder climates. Eventually you'll want to replace those with vinyl, wood, fiberglass, or composite.
If you are looking for "bang for the buck", my recommendation would be to get a home energy audit. You'll get a comprehensive list of where your problem areas are, as well as what type of return you can expect in improved efficiency... and don't confuse a certified energy audit with some of these jokers running around doing "energy analysis". A real audit will consist of a blower door test, thermal cam analysis, safety checks on combustion appliances, computer modeling to determine potential savings, and then a post test afterward to make sure that the work was done right. Many states and municipalities have incentives for both the audits and/or the weatherization work. Even if you don't have such a program, you'll pay a few hundred bucks for invaluable info on the performance of your home.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| The Following User Says Thank You to HomeSealed For This Useful Post: | joecaption (02-28-2013) |
#6 |
Insulation issue?
When I bought my home many years ago I was kind of shocked at the high heating bills during the winter months. The following fall I decided to add additional insulation in the attic so I added R-19 fiberglass insulation rolled across the rafters. My gas bill dropped in half the next year.
| The Following User Says Thank You to Dave Sal For This Useful Post: | creeper (03-02-2013) |
#7 |
Insulation issue?
Improving your attic insulation to the appropriate levels is easily one of, if not the best "bang for the buck" that you can get in terms of energy efficiency.
If you are going to do it though, do it right. Research the appropriate materials, make sure that your ventilation is adequate, AIR-SEAL, etc. Cutting energy usage in half is highly uncommon, but there is certainly significant gain to be had.
#8 | |
Insulation issue?Quote:
idk what the PO's actually had for a gas bill. they told me "a very affordable $100 a month, all year, plan" , and i bet it was higher. just the work i have done so far, about 1/4 of the total plan, we are just over $100 a month in the dead of winter.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. i didn't make this world. i just live in it. be careful of whom you make fun of. one day, that could be you... |
#9 |
Insulation issue?
oh. and it is a very comfortable 73 in here. AND i plan to cut that bill in half, at least, with the finish of the work.
#10 | |
The reason that I suggested an energy audit, is that it will take a reading on the "tightness" of the home before and after the installed measures. The reason this is important is that in some cases, when a home is very well sealed, mechanical ventilation in the form of a constant run exhaust fan (or worse) can be necessary to prevent excessive moisture in the home. Even worse, if the home has any naturally drafting appliances such as a furnace or water heater, there could be serious safety concerns due to back drafting.
| Display Modes | |
| Insulating your attic | Bob Mariani | How To Guides | 4 | 06-09-2013 11:48 AM |
| Basement Ext Wall - Will Rigid Insulation allow my wall to dry inward? | COLORADOMTNMAN | Insulation | 10 | 01-15-2012 11:09 PM |
| Reusing Deteriorated Insulation | a_lost_shadow | Insulation | 2 | 12-18-2011 05:27 PM |
| Yes, Another Basement Insulation Question | Beepster | Insulation | 7 | 11-30-2011 07:30 PM |
| Fixing multiple attic electrical issues before blowing in insulation | darlingm | Electrical | 11 | 11-19-2011 10:19 AM |
