Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 02-27-2013, 05:53 AM   #1
Insulation to help with sound
We are tearing down the Sheetrock in our living replacing (2) new windows. I know about the STC rating which can reduce sound but I was wondering if there was insulation that helps reduce sound. I would like to put it in the wall facing our BUSY road. Thanks
Mstrlucky74 is offline   Reply With Quote
Old 03-02-2013, 02:19 AM   #2
Roxul.
Old 03-02-2013, 10:26 AM   #3
yep = Roxul. if you have the room, fur out the studs to add thicker roxul.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 03-02-2013, 11:42 AM   #4
MikeKy55's Avatar
Originally Posted by jklingel View Post
Roxul.
I second or third this. When I finished my basement I used Roxul in all the ceilings and it amazed me how well it controls sound. It's user friendly as well. No fiberglass dust to deal with and you cut it with a kitchen knife.
'It's never too late to say ''THANK YOU'' to a veteran of our armed services'
MikeKy55 is offline   Reply With Quote
Old 03-03-2013, 09:16 AM   #5
true. but it is dusty and dirty. work it gently so to keep the dust down.
Sound reduction with insulation atDev Insulation 3 08-09-2012 10:08 PM
Ceiling Sound Insulation OhioDon Insulation 11 06-12-2012 01:57 PM
Basement Exterior Above Grade Insulation purpasadu Building & Construction 6 02-28-2012 05:42 PM
Insulation with Sound Isolation Clips atmironov Building & Construction 12 05-06-2010 04:44 PM
sound insulation between 1st & second floor gretchenmay1 General Discussion 1 02-15-2010 05:42 PM
