Insulation Hanging Below My Bay Window - Insulation - DIY Chatroom Home Improvement Forum
Old 05-12-2014, 11:36 PM   #1
Rewards Points: 18
Insulation hanging below my bay window
I recently purchased a 1906 colonial in Milwaukee, WI.
While trimming the bushes I notice insulation hanging from the bay window (below the protruding window where there is maybe 3 feet of clearance before the dirt/ ground.
It looks like that insulation used to be held in place by a thin piece of sheet plywood.
Should I replace the plywood and screw/ nail the opening closed or should I first rip out the old insulation (in case it got wet or in case there are birds in there), and then seal up the opening?
Thank you!!
Milwminded is offline   Reply With Quote
Old 05-12-2014, 11:51 PM   #2
Rewards Points: 166
Insulation doesn't cost too much. If it was me I'd pull it out, check the wall cavity for insect/animal damage, then replace it and seal everything properly.
dftc is offline   Reply With Quote
Old 05-12-2014, 11:56 PM   #3
Rewards Points: 6,652
Pictures, pictures, pictures.
The Following User Says Thank You to gregzoll For This Useful Post:
roofermann (05-13-2014)
Old 05-13-2014, 06:16 AM   #4
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Typically there is a reason that this happens such as moisture damage, etc, so I'd do some further investigation on that prior to reattaching.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
The Following User Says Thank You to HomeSealed For This Useful Post:
joecaption (05-13-2014)
Old 05-17-2014, 07:12 AM   #5
Rewards Points: 18
Photo 1
Photo 1
Old 05-17-2014, 07:17 AM   #6
Rewards Points: 18
Photo 2
Photo 2 is looking up from the ground into the bay window where there is only flimsy wood paneling between the Wisconsin elements and the insulation. Actually, as you can see, a section of the wood paneling had fallen off and now there is nothing between the insulation and the weather/ elements...
Old 05-17-2014, 07:22 AM   #7
Rewards Points: 18
Photo 3
Photos 3 is the wood paneling that runs the length of the bay window "bottom" where one section has broken off and the insulation is coming through that missing section. The remaining paneling is bowed.
Old 05-22-2014, 06:16 PM   #8
Registered User
Rewards Points: 526
That thin veneer paneling is for interior applications only. Add some rigid foam board and sleepers, then plywood- all air-sealed as in fig. 7 to decouple it from the cold ground temps; http://www.buildingscience.com/docum...n-crawlspaces/
Gary
PS. Welcome to the forums!
The Following 2 Users Say Thank You to Gary in WA For This Useful Post:
HomeSealed (05-27-2014), Windows on Wash (05-23-2014)
Tags
insulation
Hanging Window Blinds Budfudder Drywall & Plaster 3 03-31-2014 09:30 AM
Changing Window Size TinaV Remodeling 3 11-06-2012 12:30 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 05:00 PM
