Insulation hanging below my bay window
Tags
insulation
1K views 7 replies 5 participants last post by  Gary in WA
I recently purchased a 1906 colonial in Milwaukee, WI.
While trimming the bushes I notice insulation hanging from the bay window (below the protruding window where there is maybe 3 feet of clearance before the dirt/ ground.
It looks like that insulation used to be held in place by a thin piece of sheet plywood.
Should I replace the plywood and screw/ nail the opening closed or should I first rip out the old insulation (in case it got wet or in case there are birds in there), and then seal up the opening?
Thank you!!
#8 ·
#6 ·
Photo 2
Photo 2 is looking up from the ground into the bay window where there is only flimsy wood paneling between the Wisconsin elements and the insulation. Actually, as you can see, a section of the wood paneling had fallen off and now there is nothing between the insulation and the weather/ elements...
