Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 05-23-2011, 11:22 AM   #1
insulation - faced or unfaced and which direction
two situations:
1) a bathroom and shower room in a mens locker room. The area is has CMU block walls with a attic area above. This is a commerical use locker room. The ceiling area is getting new insulation, and drywall, with a drop ceiling below the sheetrock. Does a vapor barrier need to be install? Which side of the insulation would the barrier need to go?
2) installing insulation on the wall and ceiling of a metal building. What kind of insulation to use? Faced or unfaced and with side to put the faced ( to the inside or outside of the metal building?
neil buckner is offline   Reply With Quote
The Following User Says Thank You to neil buckner For This Useful Post:
john020496 (01-16-2012)
