-   Insulation (http://www.diychatroom.com/f103/)
-   -   insulation - faced or unfaced and which direction (http://www.diychatroom.com/f103/insulation-faced-unfaced-direction-105314/)
neil buckner 05-23-2011 10:22 AM
two situations:
1) a bathroom and shower room in a mens locker room. The area is has CMU block walls with a attic area above. This is a commerical use locker room. The ceiling area is getting new insulation, and drywall, with a drop ceiling below the sheetrock. Does a vapor barrier need to be install? Which side of the insulation would the barrier need to go?
2) installing insulation on the wall and ceiling of a metal building. What kind of insulation to use? Faced or unfaced and with side to put the faced ( to the inside or outside of the metal building?
