Insulation : Faced And Unfaced - Insulation - DIY Chatroom Home Improvement Forum
Old 02-14-2012, 09:00 PM   #1
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Insulation : Faced and unfaced
I have to be honest : I don't really understand the concept of faced vs unfaced, and when one should use faced in lieu of unfaced.
Can someone explain this to me?
Journeyman Plumber
Old 02-14-2012, 09:01 PM   #2
Doing it myself
Alan's Avatar
Argh. I think i found the answer I was looking for.
Journeyman Plumber
Old 02-14-2012, 09:16 PM   #3
Doing it myself
Alan's Avatar
Ok, but I do have a question that I can't seem to answer by looking at the requirements that I found.
Is insulation required between floors? If so, what R-Value does it need to be?
zone 4C.
Journeyman Plumber
Old 02-14-2012, 09:45 PM   #4
Registered User
Rewards Points: 526
Only between a conditioned (living space) and an unconditioned one--- crawlspace/main floor, attic/upstairs floor.
http://publicecodes.citation.com/ico..._11_sec002.htm
Vapor barriers: http://www.buildingscience.com/docum...commendations/
Certain exterior insulation mute the v.b. requirement: after reading, hit "next section" , etc., etc., etc.http://publicecodes.citation.com/ico...001_par003.htm
Gary
Old 02-16-2012, 08:30 PM   #5
Doing it myself
Alan's Avatar
Hey Gary,
I was reading another thread on this topic and I saw that you said something about taping the seams on the facing. What kind of tape is normally used for that? Plain old duct tape?
To take that one step further, I assume it would be a good idea to tape around electrical boxes and pipes that stick through the facing as well?
Journeyman Plumber
Old 02-17-2012, 03:13 PM   #6
Registered User
Rewards Points: 526
Originally Posted by Alan View Post
Hey Gary,
I was reading another thread on this topic and I saw that you said something about taping the seams on the facing. What kind of tape is normally used for that? Plain old duct tape?----
I'd be surprised if I said to tape a rip in the facing paper. The facing is area-weighed so any slash, rip, tear, hole doesn't matter much; https://docs.google.com/viewer?a=v&q...9yRrrdP1VBztDg
Air sealing is a different subject. Yes, air seal the drywall (ADA): http://www.buildingscience.com/docum...wall-approach/
Make sure the insulation is touching the drywall to prevent convective loops, though low-density f.g. has inherent c.l.'s: http://www.buildingscience.com/docum...ty-insulation/ Don't inset staple walls.
Gary
Old 02-17-2012, 07:50 PM   #7
Doing it myself
Alan's Avatar
Very good reads there. Thanks a lot.
Something else crossed my mind while I was reading that, so here it is :
If you're supposed to cut the insulation to fit tightly around obstructions (IE : electrical boxes) what should be done between the electrical box and the subsiding in an exterior wall? Compressing the insulation to fit isn't a good idea from what I was reading. What other option is there?
Journeyman Plumber
Old 02-18-2012, 01:49 PM   #8
Rewards Points: 626
when you install around a electrical box you slit the batt place half behind it then cut the front out top bottom then fold in and place to the side. I whis I had a photo of how to do this. Next time i do a insulation job I will take photos and post.
Nailbags is offline   Reply With Quote
Old 02-22-2012, 08:19 PM   #9
Doing it myself
Alan's Avatar
That would be awesome.
Journeyman Plumber
Old 02-23-2012, 09:35 AM   #10
Doing it myself
Alan's Avatar
I was looking at some videos and they brought me to this :
Since my exterior walls are 2x4 would it be better to spray foam behind the electrical boxes? Would I get better R-value out of 1 to 1-1/2" of spray foam than I would with fiberglass batts cut to fit?
Journeyman Plumber
Old 02-25-2012, 09:01 AM   #11
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,250
That is correct.
Seal up the electrical boxes as well so that when you drywall, the wall is tight on both sides.
When the wall is exposed, seal every gap, crack, or air loss point you can spot.
Air loss is far more critical to efficiency than R-Values in most cases. Air loss is also much more responsible for moisture issues than faced vs. un-faced insulation.
It carries about 100X as much water as a faced vs. un-faced question.
R-30 Faced/ unfaced insulation bhanse Insulation 6 01-08-2012 07:29 PM
Insulation - Faced vs. Unfaced + Plastic Sheet WaldenL Building & Construction 4 07-06-2011 11:41 AM
insulation - faced or unfaced and which direction neil buckner Insulation 0 05-23-2011 10:22 AM
Faced vs unfaced insulation in basement? mathias400 General DIY Discussions 0 05-19-2010 10:01 PM
Faced or Unfaced Insulation in Attic??? capenpeck Building & Construction 13 11-06-2009 07:23 AM
