Insulation In Crawl Spaces - Insulation - DIY Chatroom Home Improvement Forum
Old 10-30-2012, 11:32 AM   #1
insulation in crawl spaces
I have a spare bedroom that gets a little chilly and it has two crawl spaces with doors on each side of the room. There is insulation in there but not on the ceilings. I was wondering if I should put some sheets of insulation up on the ceiling and if it would help with keeping the room warm. I have attached some pictures to give you guys a better idea of where I am wanting to put insulation. Let me know your opinion guys! Thanks!
mckain0919 is offline   Reply With Quote
Old 10-30-2012, 11:42 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,582
This would more aptly be referred to as a knee wall storage area.
If you search around the board, you will see a host of these threads about the proper insulation and air sealing details that will help mitigate these comfort issues.
The cliff notes are:
  • install blockers in the joist bays and air seal
  • air seal all penetrations in the wall, sill plate, and top plate
  • back the exposed wall with either a combination of rigid foam and/or batt insulation to thermally uncouple the framing
Basement Exterior Above Grade Insulation purpasadu Building & Construction 6 02-28-2012 04:42 PM
crawl spaces are complicated pwa Building & Construction 16 07-03-2011 05:25 PM
Floor insulation for small room over inaccessable crawl space. EdT Insulation 0 05-13-2011 11:25 AM
Insulation for crawl space howard.wheaton Remodeling 3 10-17-2008 09:53 PM
foam brick as crawl insulation DangerMouse Building & Construction 4 07-25-2008 10:17 AM
