Insulation Conundrum - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-29-2012, 04:53 AM   #16
Rewards Points: 95
The important thing is the water vapor that you and your family create in your home.
Water vapor comes from cooking, washing, breathing, indoor plants, fish tanks, chikdren, animals.
Water vapor always moves from warm to cold.
If the inside of your walls and roof are cold, water vapor will condense on the wood and if it cannot dry, will create mold and in time wood rot.
If you fix polystyrene sheets, or some similar closed cell insulation over the outside, you will keep the frame and everything else inside warm.
Close fitted sheets of polystyrene are both wind proof and water proof.
If you fit water vapor proof plastic sheets between the frame and the polystyrene you will have a cosy dry home.
Perry525 is offline   Reply With Quote
Old 04-29-2012, 09:22 AM   #17
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
Perry,
With all due respect, this last statement is completely wrong and terrible advice.
This clients climate zone does not require a Class 1 vapor retarded and putting one to the exterior of the home is both unnecessary and ill advised.
Not only will you be created a double vapor retarder between the foam and the plastic, but you will actually be trapping any accumulated moisture inside the space between the foam and the framing and/or the interstitial wall space and the foam.
Air barrier detailing on the foam should be very careful, redundant, and perhaps duplicative.
If the homeowner removes the fiberboard, they can quite easily air seal the entire interior wall and therefore reduce (probably by about 100X) the amount of moisture coming into the inside space of that wall via bulk air transfer.
Putting a well applied and seal foam to the exterior (provided of sufficient depth and R-Value) will keep moisture from entering from the outside and keep the framing well above dew point and eliminate the potential condensation problem.
Putting plastic between the plastic foam and the home is not recommended.
Everything else that you said was spot on with the exception of that last statement.
The Following 2 Users Say Thank You to Windows on Wash For This Useful Post:
crankcase (08-03-2012), Tom Struble (04-29-2012)
Old 04-29-2012, 02:53 PM   #18
Well I'm curious to see what the various contractors I have coming to give me quotes have to say. We'll see if they know what they are talking about or just blowing smoke.
Lioncourt is offline   Reply With Quote
Old 05-01-2012, 10:10 PM   #19
Registered User
Rewards Points: 526
They may tell you cellulose doesn't need a vapor barrier: http://www.applegateinsulation.com/C...id=249418&fd=0
http://www.cellulose.org/HomeOwners/...orBarriers.php
Gary
Old 05-05-2012, 02:00 PM   #20
So I've got 1 company striping the house to the sheathing and installing the Prodigy insulated siding over Rain Drop house wrap. I've got another that wants to leave the asbestos cement tiles and side over it with brigade board insulation and Mastic XL55 (i think the brigade board replaced the fanfold he suggested when i said i wanted more insulation). Thoughts?
Old 05-05-2012, 10:41 PM   #21
Rewards Points: 1,548
Originally Posted by Lioncourt View Post
Interesting, I've never heard of a house without some form of sheathing (not just foam) I know the fiberboard isn't much for rigidity but Shouldn't there be something like an OSB or plywood to reduce stress on the drywall?
I have . Example: studs with some diagonal bracing, foam or rigid fiber glass insulation. Vinyl siding on the outside, the usual drywall on the inside.
(Vapor barrier on the inside just behind the drywall if the insulation itself is not impervious.)
Old 05-06-2012, 08:38 AM   #22
We always prefer to strip the exterior walls and get the asbestos off and done.
Insulated siding doesn't add any real appreciable amount of R-Value as compared to what is quoted.
Old 05-06-2012, 11:01 AM   #23
I don't follow your second comment. Each system seems to add about R4 which is better than nothing
Old 05-06-2012, 11:34 AM   #24
Insulation only works when it is in direct contact with the substrate and the contact is 100%. The reality is that your exterior walls are less than plumb, level and true. As a result, most homes with insulated siding will only have what we refer to as intimate contact at about 50% (or less) of the wall surface area.
This means that you will only have 50% of the intended R-Value realization.
Couple that with the fact that the quoted R-4 is also misleading (they are measuring the R-Value at the thickest section of the foam and the foam is actually tapered so the overall R-Value is closer to about 60-70% of that in most cases) and you are lucky if you are going to get and R-2 average improvement.
Foam backed siding was invented for rigidity and not for the supposed R-Value improvement. Once the "green" movement took off, the ability to cross promote took off.
If you are really looking to thermally break the exterior wall, the only way to do it is with rigid foam installed and properly fastened to the home.
Sorry if that is a bit of a let down but having seen before and after IR images of homes with insulated siding, the improvements are less than fantastic.
Old 05-06-2012, 03:38 PM   #25
Ok so here is what I'm thinking. With the budget I have strip off the siding including the tiles down to the sheathing. cover the foundation/silplate/rim joist/flooring area in ice & water shield to seal up all air infiltration there. Follow with the brigade board and xl55 siding. I know it's not ideal but I'm afraid adding much more in the way of foam would make me build out my window frames a lot. Any thoughts on this whole system? would you replace the brigade board with something different? (I think the alside prodigy is too costly)
Old 05-11-2012, 07:45 AM   #26
Rewards Points: 95
If you stand in front of a mirror in your bathroom and breath slowly onto the mirror you will see condensation, even though the mirror is 22C/70F or more degrees, this is because or breath is saturated with water vapor at body temperature.
From the scale below you will see that condensation forms as the result of both temperature and humidity.......if you take into account your expected indoor average temperature and average humidity this will give you the dew point at which condensation will form.
From this, you can ascertain how much insulation you need on the outside of your frame, to ensure the frame is always above the expected dew point.
Keep in mind that some of us expect to use our heating for at least some of the year, and some of us keep the inside of our homes warmer that the outside, in these circumstances as heat always moves to cold and water vapor always moves from warm to cold or to an area of low pressure , there is no possibility of water vapor moving into a home that is warmer than the outside air.
Down south where it is warmer all year round, or in homes where air conditioning is used to keep the inside air temperature lower than the outside air temperature, then the warmer outside air and higher water vapor will move inwards where there is insufficient insulation.
If you are fitting a water vapor proof membrane without sufficient backup insulation, this requires extreme care as water vapor molecules are very tiny and they will find there way through the smallest crack or hole.
Drywall is invisible to water vapor, water vapor moves easily through drywall, at a temperature of 30C/86F and 100% humidity indoors and an outdoor temperature below dew point something like a litre of water vapor can move through a 8x4 sheet of drywall in 24 hours.
While timber may be kiln dry when installed with a water content of between 6 and 12% over time it will adjust to its local environment. Getting wet and then drying again does little harm, and with a typical uninsulated home, full of drafts this isn't a problem. Create an almost air tight well insulated home where the timber cannot dry may cause a problem.
While the water content is below 16% there is no mold, below 19% there is no rot.
Dew Point Calculation Chart (Fahrenheit)
%RH AMBIENT AIR TEMPERATURE IN FAHRENHEIT
20 30 40 50 60(70)80 90100 110 120
90 18 28 37 47 57 67 77 87 97 107 117
85 17 26 36 45 55 65 75 84 95 104 113
80 16 25 34 44 54 63 73 82 93 102 110
75 15 24 33 42 52 62 71 80 91 100 108
70 13 22 31 40 50 60 68 78 88 96 105
65 12 20 29 38 47(57)66 76 85 93 103
60 11 19 27 36 45 55 64 73 83 92 101
50 9 17 25 34 43 53 61 70 80 89 98
50 6 15 23 31 40 50 59 67 77 86 94
45 4 13 2 29 37 47 56 64 73 82 91
40 1 1 18 26 35 43 52 61 69 78 87
Old 05-12-2012, 04:29 PM   #27
Lets take this in a new direction. What if I hold off on the siding and start tearing into the inside. If I take my 2 back cold rooms and strip the drywall from the inside I can replace the windows, air seal and insulate(other rooms to follow as money allows). In this scenario would you use un-faced or faced batts? would you install a vapor/air barrier between the insulation and the new drywall? anything to watch out for?
Old 05-14-2012, 12:43 PM   #28
Rewards Points: 95
Keeping in mind that heat always moves outwards towards
cold.
And that we typically open a window or door to cool down, or
close the window or door to warm up, it follows that the outside
is nearly always colder and drier than the inside. In heating
zones.
When it comes to insulation, the inside of a room, will require
much less insulation at lower cost, to do a better job, than fitting
insulation to the outside, with the adjustments to windows and
doors leading to an odd looking building.
When you add up the amount of timber in the average wall,
(more than 1/8th is solid timer) and take into consideration ,
that usually the warm inside air is directly in contact with a
surface that connects directly to the outside cold air, providing
a solid path for conducted heat, you quickly realize that adding
a poor quality insulant between the frame, will have a poor
result.
A better consideration is, drywall, backed by a water vapor
proof plastic sheet, backed by at least three inches (preferably
more) of tightly butted polystyrene board, this will provide a
workable surface, followed by a water vapor proof plastic
sheet, backed by insulation that will ensure the inside surface
of the plastic sheet is kept above "dew point" to avoid
condensation. Should any water vapor find its way through the
plastic and polystyrene, it will move onwards and outwards.
If you stop and consider that most heat is lost through holes,
then by conduction through the frame, then think how one might
create a sealed room, like a plastic airtight/water vapor tight
box, then add to this three to ten inches of sheet polystyrene
over the inside and between the sticks, of the outside walls,
ceiling and floor (a floating insulated floor is very worth while)
then you can begin to understand how to save money on
heating and cooling.
Of course you have to consider controlled ventilation, which
tends to spoil things, or you can open a window and or use a
dehumidifier to soak up the trapped water vapor.
A well insulated home is something you will enjoy, no only in the
coldest nights and hottest days, but through out the year - there
will be many days and nights when you will be comfortable,
without cost.
And this continues for the life of the building! Dow have been
selling Blueboard/Styrofoam/polystyrene for 51 years and the
stuff installed in the early days is still as good a new. I started
using it to insulate homes 40 odd years ago.
This can be done a bit at a time, starting by finding and filling all
the holes and cracks, then insulating the ceiling, followed by the
outside walls and finally the floor.
Old 06-12-2012, 04:21 PM   #29
foam insulation and hvac
hello my name is jason,
i am working closely with a friend(builder) building a 3000 sq ft home. i opted for foam insulation and zero clearance wood burning stove. the idea being to heat most of the house with the stove. the hvac contractor (supposedly knew) i was foam insulating but now says he didnt know. we went with an 80% lennox unit with the thought we didnt need a 90% due to the stove. the insulation guy told me i needed a 90% because of the foam and fresh air issues. i have the feeling my builder and/or the hvac guy wont say they made a mistake. now my builder states i can build plywood boxes over my units and pipe in fresh air for the 80% unit. sounds funny to me.
if anyone knows what i need to do please help?! thank you
ocfd47543 is offline   Reply With Quote
Old 06-13-2012, 05:04 AM   #30
Rewards Points: 95
Jason, I've tried heating a home with a wood burner, I've had it red hot to five feet up the chimney, when you could'nt stand within 6 feet, it was so hot -but the heat didn't travel into the other rooms.
The best form of heating is hydronic, water is better at moving heat than dry air. Its 4,000 times better.
A hot water system with base board heating works best, its quick to cool down, when the sun comes out.
Tags
insulation; foam; wall , siding vinyl
Attic insulation over old attic floor beffreyj3 Insulation 6 11-18-2011 07:21 AM
Which insulation? Photos attached of room homiefb Insulation 1 08-16-2011 05:44 AM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
Has anyone used Green Fiber blown in insulation? pomelo Building & Construction 7 02-10-2010 07:17 AM
