Insulation Code Question - Insulation - DIY Chatroom Home Improvement Forum
Old 01-23-2012, 02:09 PM   #1
Rewards Points: 131
insulation code question
is there any rule says min distance between fiberglass/foam and gas/hot water/heating supply pipe/vent or electrical wire? i know there usually has 3" min distance between light housing and insulation, what about other stuff.
s002wjh is offline   Reply With Quote
Old 01-23-2012, 02:35 PM   #2
Residential Designer
AndyGump's Avatar
Rewards Points: 688
Send a message via Skype™ to AndyGump
None that I am aware of, none of those building elements get hot enough to worry about proximity to insulation.
On a side note, they make light fixture boxes that you can put right next to insulation, they are called IC for Insulation Contact.
Andy.
AndyGump is offline   Reply With Quote
Old 01-24-2012, 07:17 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
Andy.
+1 on the light cans
None that I know of but I am sure that GBR will have a link.
I wouldn't worry about a properly shielded electrical wire or normal temperature (residential) hot water pipe.
Old 01-24-2012, 04:17 PM   #4
011010100110111101100101
Rewards Points: 160
Fiberglass batt is what is inside wood stoves
The kraft paper however WILL burn, but not against a hot water pipe or even steam pipe.
The 3" is for recessed lighting. A normal hex box with a fixture doesn't require blocking. A 1970s can light would unless it's listed for direct contact as mentioned above.
-- Joe
anesthes is offline   Reply With Quote
Lighting proximity to outdoor hot tub - Code Question jeffinpickering Electrical 0 09-12-2011 01:43 PM
Another Rigid Insulation over Block Question jdon88 Building & Construction 1 02-16-2011 10:25 PM
Basement Insulation Question gilbo125 Building & Construction 9 02-01-2011 04:13 AM
Same old Question basement Insulation advice rp92285 Building & Construction 2 02-05-2010 11:01 AM
ceiling insulation question christy123 Roofing/Siding 15 12-18-2008 12:22 AM
