Insulation For Childs Room - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-18-2013, 01:03 AM   #16
Originally Posted by Windows on Wash View Post
It will be mucho expensive via the froth packs and twin tank kits and the yield is terrible.
The original poster can do a whole lot with proper air sealing, rigid foam, and high density batts.
Amen to that!
RTC_wa is offline   Reply With Quote
Old 03-18-2013, 01:08 AM   #17
Originally Posted by JPL View Post
www.sprayfoamdirect.com. I say the same thing about A/V and automation systems. Yet every Tom, Dick and Harry thinks they know it all and can install those things PROPERLY. If you take the time and research what you're doing, DYI is possible with nearly everything.
to do it right, if you take the square footage of a new construction home say 3,000 sqf you need to multiply that by 3 to get the total amount needed. that is 9,000 square feet R-21 in walls and R-48 in attic is over 64,000 dollars. how many years will it take in energy savings to pay it off? to answer that it will take 129.8 years to break even. now if you add just 1 inch of that garbage and then add batts to it it will take 30 years to pay for itself yeah! were as fiberglass batts at .52 cents per square foot will take right around ten years to pay for itself and if you went with cellulose be about the same number of years. So dump the foam.
Old 03-18-2013, 08:04 AM   #18
Rewards Points: 22
Wow, Lots of answers here! I'm sorry I didn't check earlier. I'm in New York, on Long Island, prob 5 miles or so from the Ocean (one town over from Long Beach, NY). This is not a huge room so cost is a factor but not a big one. I don't want to overthink it as the pink stuff would probably do the job, but yes that room is on the shady side of the house and takes a direct hit from the wind. It's always noticably cold in there, but as of now there is zero insullation.
One of buds just rebuilt part of his house after Sandy. He said he used the hard foam stuff and it wasn't too difficult to install. I might go that route and look into proper air sealing etc as suggested.
Thanks again,
Rick
Mantaray14 is offline   Reply With Quote
The Following User Says Thank You to Mantaray14 For This Useful Post:
asinsulation (03-18-2013)
Soundproofing a basement room MrAngles Insulation 5 06-06-2012 09:01 PM
Ideas for retrofitting baffles/insulation in vaulted ceiling of built out attic room rachelsue20 Insulation 5 04-28-2012 07:49 PM
Basement Exterior Above Grade Insulation purpasadu Building & Construction 6 02-28-2012 04:42 PM
Well Room (Cold Room) Issue--Advice Needed TomPgh Building & Construction 11 01-03-2011 06:31 PM
