-   Insulation (http://www.diychatroom.com/f103/)
-   -   Insulation for Childs Room (http://www.diychatroom.com/f103/insulation-childs-room-174524/)
Mantaray14 03-14-2013 02:56 PM
Hello everyone,
I am going to start a project soon. My son's room has alway's been the coldest room in the house. Not only is there no insulation (none of the original rooms have it), but his room takes a direct hit from the wind, creating a strong draft there. To make matters worse, the original owner tried to tack up some kind of "stick-on" wall board in an attempt to make he walls thicker and now the walls are in terrible shape.
So it's time for the walls to come down, and some nice new insulation and sheet rock (and paint and trim of course) to come in.
My question is this. I hear there's all kinds of new insulation products out there. One friend says theres this "denim" product that best, another friend tells me he just used some kind of foam board and thats the best. Obviously for my child I want whatever will help that room stay warm and keep those drafts out in the wintertime. Any suggestions would be aprecciated!
Best Regards,
Rick
TrailerParadise 03-14-2013 03:34 PM
i just used regular R-13 Kraft-faced fiberglass roll insulation. My floors arent even insulated yet, but you can definitely tell the difference in rooms that have the new stuff, and the rooms that dont. For example, the master bedroom is completely insulated and drywalled now, the bathroom is not. In the bedroom, you're sweating even in 30 degree weather outside. The windows arent anything special, either. In the bathroom, you're freezing. So just normal R-13 will make a huge difference. That denim stuff is supposed to be really great but its also really expensive, and so is foam. Just a heads up.
joecaption 03-14-2013 05:32 PM
#1 you need to go back and add your location to your profile for this type question.
Just go to quick links to edit.
Got some pictures, drawings.
http://www.energystar.gov/index.cfm?...sulation_table
asinsulation 03-14-2013 06:22 PM
depends ENTIRELY on your location what the best solution would be, but remember, there is more then one solution. There is no such thing as bad insulation, just bad installation. I can recommend a little more with your region though.
redman88 03-14-2013 09:06 PM
everything i have read about insulation its all about where you are, because you might have to install a vapor barer. and don't forget the second you open up the walls, to do more the minor drywall patch work, you have to bring electrical up to code, and other items in the wall.
RTC_wa 03-15-2013 02:31 AM
Originally Posted by Mantaray14 (Post 1137270)
Hello everyone,
Best Regards,
Rick
Well first of all were are you located at would help. I know using old jeans is not the best. why? because that material can be reused in to making new cotton clothing and farming cotton is the hardest crop on the soil it depleats the nutrients of the soil faster then any crop out there so the more we can really recycle the better plus if you live in a humid climate it draws in moisture. I would just stick with Batts of Fiber glass. After having two contractors come out to add insulation to my attic one that used paper mulch and one that used Fiber glass I have to say I am using the Fiberglass guys even the paper mulch man said it is bad to use in the damp northwest out in the cost were I live. So I think it depends on were you live and stuff For me I would just use the pink stuff.
Windows on Wash 03-15-2013 07:03 AM
+1
Pictures, location of the home, and budget will help get you the most comprehensive answers.
Denim is not the best solution by any stretch and there are a myriad of products that will do the same thing with minimal environmental impact.
AllanJ 03-15-2013 09:03 AM
Be sure that the insulation batts are fluffed properly to cut down on air moving about in the stud cavities which increases heat loss.
Caulk the window frames as needed. Old style windows with sash weights have additional heat loss and possible additional drafts through the spaces where the weights hang.
TrailerParadise 03-15-2013 09:44 AM
RTC and Windows: There is actually a type of insulation that is made from recycled denim, and i think that is what OP is talking about. Its supposed to work great but its like $5 per square foot. Ive never seen it in person, but it was a choice offered on Run my Renovation once.
RTC_wa 03-15-2013 12:07 PM
It is 100% ungreen that denim could have been reused to make new Blue jeans etc. so to not have to farm cotton as much. Got to look at the real big picture here. Plus it absorbs moisture like a spounge it wicks it up! soaks it up. and that can cause other problems I am sure of. oh and when I insulated my walls for my living room I caulked the bottom plate and the joint between the two top plates and ran a bead of good stuff foam low expansion foam on all the inside corners of the studs. then I put in new R21 high density batts I paid .52 cents per square foot for. I also put these on my outlet boxes too http://www.energyblock.com/install.php those will really stop air flow from the outlet boxs.
rckkrgrd 03-16-2013 01:12 PM
As others have said, location is important
I have a blog post on this subject That you might find useful
JPL 03-16-2013 11:31 PM
Closed cell spray foam. R7 per inch, no air infiltration. Google it- it's a DYI product. Not cheap, but totally worth it.
Windows on Wash 03-17-2013 11:08 AM
It will be mucho expensive via the froth packs and twin tank kits and the yield is terrible.
The original poster can do a whole lot with proper air sealing, rigid foam, and high density batts.
asinsulation 03-17-2013 03:59 PM
Spray foam is one product that should NOT be done DIY...lol
JPL 03-17-2013 10:32 PM
www.sprayfoamdirect.com. I say the same thing about A/V and automation systems. Yet every Tom, Dick and Harry thinks they know it all and can install those things PROPERLY. If you take the time and research what you're doing, DYI is possible with nearly everything.
