Insulation In Carport - Insulation - DIY Chatroom Home Improvement Forum
Old 10-15-2013, 11:03 PM   #1
Rewards Points: 97
insulation in carport
I have a carport with an enclosed room above it. Currently the carport ceiling consists of 2 x 10 fibreglass batts covered by 1/4 plywood. No vapor barrier. Is there a better way to insulate the room above?
bcbud3 is offline   Reply With Quote
Old 10-15-2013, 11:30 PM   #2
Post a photo, I would like to see it.
Hardway is offline   Reply With Quote
Old 10-16-2013, 06:36 AM   #3
Bill Kearney
Rewards Points: 1,174
Sprayed foam would certainly be an improvement. It'd give you both insulation and a vapor barrier at the same time. Not as inexpensive as batts, of course, but the increased insulation would be likely to do a lot to reduce energy loss.
wkearney99 is offline   Reply With Quote
Old 10-16-2013, 05:34 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,568
Yes but how much do you want to spend.
Rigid foam (Seams taped and sealed) would help by thermally uncoupling the framing and providing some of the vapor retarder layer. Depending on where you are in Canada, the vapor control layer would, in theory, need to be on the warm side but breaking the thermal bridge of the framing and having the cavity airtight will go a long way.
I would pull down the 1/4 ply, make sure the bays are air sealed and full of a HD batt, cover the framing with 2" XPS, and re-cover with plywood. That would make for an efficient floor with roughly R-45 in it.
+1
OC Spray foam is not considered a vapor barrier at any applied depth.
CC SPF is a Class II with enough thickness.
The Following User Says Thank You to Windows on Wash For This Useful Post:
wkearney99 (10-18-2013)
Old 10-17-2013, 01:04 PM   #5
Registered User
Rewards Points: 526
Post #4 and #6, follow the links to the source; air space yes or no?
Gary
Old 10-17-2013, 10:54 PM   #6
Rewards Points: 97
Gary
thanks
Old 10-17-2013, 11:09 PM   #7
thanks
What am I...chopped liver...?
Old 10-18-2013, 07:43 AM   #8
Rewards Points: 97
thanks everybody
The Following 2 Users Say Thank You to bcbud3 For This Useful Post:
Gary in WA (10-19-2013), Windows on Wash (10-18-2013)
Existing blow in insulation vs new insulation - Keep or redo? Jaxx Insulation 9 01-17-2014 08:26 AM
?'s about foil-faced "bubble wrap" insulation badger73 Insulation 5 06-25-2012 05:09 AM
Several Insulation Quotes, Big Decisions to make knotquiteawake Insulation 2 05-04-2012 11:16 AM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
