Insulation For Bonus Room Over Garage - Insulation - Page 3 - DIY Chatroom Home Improvement Forum
Old 06-11-2013, 12:38 PM   #31
Sorry for the non reply. surgery came up and the surgery didn't go as planned so i was down for longer then to be expected. I finially worked on the project this past weekend. So far all the firberglass insulation is out. Blown in cellulose was blown under the floor rafters. I capped off one side of the rafters and just need to do th other side to prevent airflow from going under the bonus room floor. I installed ridge vents along with atticfoil up the room rafters. Spray foamed all cracks but still a little bit more to do. once i put the roxul up can i put atticfoil over it or do i need a vapor barrier?
The insulation on the left was on the walls(notice no R-value is noted)
space in between rafters blocked and sealed
This one is kinda busy here. It's the going up to the angled wall where the top knee wall meets. Installed insulation foam board as well as blocking off the insulation of the angled wall and using foam as well. You can see the vents as well as part of the atticfoil on the roof rafters
BrianinNC is offline   Reply With Quote
Old 06-11-2013, 06:43 PM   #32
Rewards Points: 626
I would love to read what you posted but the stupid side bar for the adds blocked half your post. I hope what you did worked.
Last edited by TheEplumber; 06-11-2013 at 07:39 PM. Reason: objectionable comment removed
Nailbags is offline   Reply With Quote
The Following User Says Thank You to Nailbags For This Useful Post:
Gary in WA (06-26-2013)
Old 06-11-2013, 07:28 PM   #33
i'm still working on it. I did one side of insulation and i'll do the rest within the next week or two
Old 06-25-2013, 06:10 PM   #34
anyone have any ideas on if I can put up the perforated atticfoil over the roxul or do I need the non-perforated kind to put over it??
garage room bmorekid Building & Construction 4 01-02-2012 01:22 AM
Which insulation? Photos attached of room homiefb Insulation 1 08-16-2011 06:44 AM
Need help in deciding: room above garage CatherineMM Flooring 4 08-15-2010 04:21 PM
Room in attic insulation air gap gumbudah Building & Construction 2 04-04-2010 06:06 PM
Should I put 2x6 or 2x10 above garage if I plan to finish the room in the future? rockne Building & Construction 35 06-08-2009 10:33 PM
