Insulation For Bonus Room Over Garage - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-21-2013, 10:35 AM   #16
2500 wouldnt be a terrible price. it is a detailed, time consuming job. the cost of good business
asinsulation is offline   Reply With Quote
Old 03-21-2013, 10:49 AM   #17
He was only adding loose fill. Nothing else
BrianinNC is offline   Reply With Quote
Old 03-21-2013, 11:59 AM   #18
Rewards Points: 626
what is the square footage? you can blow that in yourself.
Nailbags is offline   Reply With Quote
Old 03-21-2013, 12:04 PM   #19
Rewards Points: 626
that is a horrible price for blown insulation I have homes that are 2,000 to 3,000 square feet all exterior walls bibbed all interior walls batted garage insulated and attic blown for 3 grand. to just do that small room for 2 grand crazy.
Old 03-21-2013, 03:24 PM   #20
Well if gary is saying i don't need to do loose fill in the unconditioned space and just under the bonus room then my sq footage is just under 300 sq ft
Old 03-21-2013, 05:12 PM   #21
well then nailbags, i would imagine they will be out of business in the end or living in an apartment forever...lol
JUST for the loose fill, no, thats not proper. but, for the airseal, and addressing the whole room comprehensively, airsealing, insulation, ensure proper venting and diagnostics to prove results, not a bad deal. Personally, I don't even offer my blow in insulation services in attics if they don't want an airseal with it.
Old 03-21-2013, 06:09 PM   #22
Rewards Points: 626
True just blow is not good.
Old 03-21-2013, 06:13 PM   #23
Rewards Points: 626
If you went with that contractor then you would be paying $6.66 a square foot I would love to see what they quoted you on.
Old 03-21-2013, 06:29 PM   #24
from one extreme to the other! if I could pull 6.66 a foot on open blow, I would have retired a looooong time ago!
Old 03-21-2013, 07:32 PM   #25
Rewards Points: 626
I just took 300sf divided it in to two thousand and you get 6.66 or what the contractor may be charging if it was only blow. but if it is to seal proper vent etc. unless you see the bid you don't get that good of image of what is really bidded. and yes i could live well charging that price.
Old 03-21-2013, 10:12 PM   #26
Well I was skeptical because he didnt measure the room or anything. He just threw out a number. We took a pass on his quote.
Old 03-22-2013, 05:12 AM   #27
jpc
jc
Rewards Points: 162
Send a message via Yahoo to jpc
Hey Brian you came to the right place, and gotten the best advice to handle that bonus room, now it's time to make it happen,lol. I'm half way done with mine, I got the outside attic kneewall area finished and soon will start on the other side that connect's to the house side and I can tell ya with just one side done it made a huge differnce. As this bonus room is actually my bedroom I spend alot of time up there.
BIG +1 on caulking/foaming those stud cavities while there still empty. I removed my FG batt's to air seal mine, that sucked lol
Take your time and do it right, and You wont regret it. Good luck with your project and keep us posted on how you make out.
jpc is offline   Reply With Quote
Old 03-22-2013, 09:02 AM   #28
Yep. On that note I can't complain. Everyone has given me great advice all around. I'm just crunching some numbers on cost right now.
Old 04-14-2013, 02:11 PM   #29
So i had to postpone doing the cellulose due to upcoming surgery this week. Put in the ridge vents already and removing some of the insullation under bonus room. here is another thing i came accross. At least 4 of the spots between the rafter are closed of with (2) 2x6 by 8ft boards. I drilled a hole and its insulated. Should i try and cut these out to remove the insulation that is in there or because it's already closed off just use spray foam to seal it up tight... In the proccess of ordering some Roxul for the knee wall
In this pic you can't tell but the board that looks like it's between the rafter is one long 8ft board.
Also i'm not able to put ridge vent like normal due to another 8 ft 2x6 here.Should i just modify using ridged foam and rafter vent at a different angle??
Old 04-16-2013, 01:22 AM   #30
Registered User
Rewards Points: 5,212
You have some unusual framing going on. No hangers, header at a rake instead of plumb, no shear continuity for the rafters/wall spread connections... do you have a better camera for another pic. from 10' away, facing the framing? Why is sunlight shinning there from above? Is this the backside of a dormer window?
Gary
garage room bmorekid Building & Construction 4 01-02-2012 01:22 AM
Which insulation? Photos attached of room homiefb Insulation 1 08-16-2011 06:44 AM
Need help in deciding: room above garage CatherineMM Flooring 4 08-15-2010 04:21 PM
Room in attic insulation air gap gumbudah Building & Construction 2 04-04-2010 06:06 PM
Should I put 2x6 or 2x10 above garage if I plan to finish the room in the future? rockne Building & Construction 35 06-08-2009 10:33 PM
