Insulation Between Joists - Insulation - DIY Chatroom Home Improvement Forum
Old 07-12-2013, 11:24 AM   #1
insulation between joists
I have a ranch that has a bedroom above the unheated garage. As I remodel the bath next to the garage now, I can see that the old insulation between the floor joists might need to be replaced. Without ripping out any drywalls in the garage, is it possible to stuff insulation in between the joists from the bathroom?
The picture attached shows the view from the bath being remodeled. The garage is on the other side of the wall and the bedroom closet is above the ceiling in the picture. You can just barely make out the crumpled looking insulation in between the joists near the center of the picture.
saimike is offline   Reply With Quote
Old 07-12-2013, 11:34 AM   #2
Rewards Points: 12,830
If someone knew at least what country and state you lived in by adding it to your profile we can make some guesses on how to do it.
http://www.energystar.gov/index.cfm?...sulation_table
No way was that garage built to code. It needed 5/8 fire rock separating it from the living space for fire protection and to prevent CO2 from getting into the living space.
Old 07-12-2013, 02:18 PM   #3
Looks like I'm on the border of Zone 4-5. The house was built in the 50s (and hardly updated) so things were very different then.
Just updated my location, sorry about that. Keep the suggestions rolling!
Old 07-14-2013, 11:38 PM   #4
Rewards Points: 81
You could do a blown in insulation (fiberglass or cellulose). Shove the hose in the cavity as far as you can and turn the machine on, then you slowly draw the hose out, filling the cavity as you go. Just an idea...
one cut is offline   Reply With Quote
Old 07-15-2013, 11:20 AM   #5
That's an interesting idea. Would there be any issues with code? I would imagine whoever rips apart the garage ceiling (not sure why one would do that, but ...) will be in for a surprise!
While I haven't tried this before, I don't suppose bats or rolls would work?
Colonial Split level drew7ster Insulation 11 01-09-2013 04:44 PM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Attic insulation over old attic floor beffreyj3 Insulation 6 11-18-2011 08:21 AM
Could asbestos be in batt-type insulation in rim joists? darlingm Insulation 3 08-30-2011 01:21 PM
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
