Insulation Between Floors - Vap Barrier? - Insulation - DIY Chatroom Home Improvement Forum
Old 04-17-2013, 07:28 PM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 1,452
Now that I've passed my framing inspection...time to insulate.....
My plans call for R30 insulation between the 1st and 2nd floor.
Should I use faced insulation (faced side to the 1st floor) or just bare bats?
Old 04-17-2013, 07:34 PM   #2
Rewards Points: 13,450
Why would you add any insulation between the two floors?
Old 04-17-2013, 08:08 PM   #3
JOATMON
ddawg16's Avatar
Because my plans say so.....I suspect it's more for noise...
Old 04-18-2013, 10:47 AM   #4
Thermal insulation does very little for noise. If you really care about noise use roxul safe and sound. Otherwise skip it entirely as it's pretty much a waste of money unless you're planning on really conditioning one floor and not conditioning the other floor at all.
mikegp is offline   Reply With Quote
Old 04-18-2013, 12:51 PM   #5
GBrackins's Avatar
Rewards Points: 2,108
I agree with mike about the roxul safe and sound, great product and user friendly. I'm sure the call out on insulation is more for sound transmission than "insulation value". if you decide on batts I would use unfaced.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 04-18-2013, 05:26 PM   #6
Registered User
Rewards Points: 5,482
It's unanimous... no faced in Zones 1-3; http://www.buildingscience.com/docum...commendations/
Some would do the stud bays of the upstairs plumbing drains, perimeter of bathrooms, under stairs, and laundry room.
Gary
Insulation and vapor barrier newhome2010 Building & Construction 18 12-21-2010 03:12 PM
Insulation and Radiant Barrier Titans Roofing/Siding 6 06-22-2010 10:46 AM
Really confused about vapor barrier and insulation JakAHearts Building & Construction 11 06-16-2010 09:54 PM
Slab, footer, block, insulation, vapor barrier & me! TinaRap Building & Construction 11 04-21-2010 04:11 PM
Radiant Barrier Insulation SPS-1 Building & Construction 0 10-26-2009 07:16 PM
