Insulation Between Cinderblocks And Drywall - Insulation - DIY Chatroom Home Improvement Forum
Old 10-05-2012, 05:37 PM   #1
Rewards Points: 49
Insulation between cinderblocks and drywall
I am removing old drywall from an exterior wall.
There is no insulation between the cinder block and drywall.
Should i install insulation? It seems like the right thing to do.
What is recommended?
The house is located in Illinois.
thanks allot
john_bry is offline   Reply With Quote
Old 10-05-2012, 06:07 PM   #2
Rewards Points: 13,300
Are you sure that's right? An exterier wall with drywall on it?
Did you mean it's on interier wall you removed it from that is an outside wall?
Spray foam or at least blue foam with low expanding spray foam to seal any gaps.
Old 10-05-2012, 06:37 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,940
Yes, it should have insulation.
There are a myriad of thread on here and building science.com that detail different basement wall insulation strategies.
Old 10-08-2012, 05:50 AM   #4
Rewards Points: 49
insulation and vapor barrier
wheres the best place to insulate a cinderblock and brick wall above grade? Is it between the cinderblock and brick?
Should that have a "vapor barrier" whatever that really means.
Vapor barrier = water impenetrable membrane?
If you have a vapor barrier one side will be wetter and the other dryer?
Should there be insulation between the cinder block and drywall or should that be allowed to breath.
insulation and vapor barrier are not the same thing.
True or false.
Sometimes you want insulation w/o a vapor barrier. Yes or no.
thx for input.
Old 10-08-2012, 10:58 PM   #5
Registered User
Rewards Points: 5,216
Find your Zone: http://publicecodes.cyberregs.com/ic..._11_par002.htm
Find requirements, read the footnotes: http://publicecodes.cyberregs.com/ic..._11_sec002.htm
Fig.4 is close: http://www.buildingscience.com/docum...gs?full_view=1
Gary
another basement insulation question, with a twist? Amateuralex Insulation 1 04-17-2012 04:11 PM
Can we glue drywall rlrife Drywall & Plaster 6 05-21-2008 06:57 PM
