Insulation Below Knee Wall - Insulation - DIY Chatroom Home Improvement Forum
Old 01-11-2012, 08:07 PM   #1
Insulation below knee wall
My house has an attic that was finished before I moved in. I had a quote to have insulation improved and part of it was to remove some of the finished floor and install rigid foam below the knee walls.
I understand that if the attic was properly finished, you would want to block the joist under the knee wall. I took a look and there is kraft R-22 spanning the entire room (from before the attic was finished). This insulation fills most of the 2x8 joist. I know that this isn't ideal, but it doesn't seem cost effective to correct this problem. Am I losing a lot of heat by not having the joist blocked off?
yaemish is offline   Reply With Quote
Old 01-12-2012, 08:16 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 906
Depends on the leakiness of the home.
The only way to get and idea of the air loss would be to actually have a blower door test of some sort.
Is there not kneewall access right now? Cutting into the finished floor seems a bit invasive and not the preferred access methodology for those type locations.
Old 01-12-2012, 11:05 AM   #3
I had an audit but not a blower door test. There isnt enough space to work behind the knee wall. However, when i took a look.at the insulation it was clean. So i dont think there is much air moving over it.
Old 01-12-2012, 03:43 PM   #4
Oh and the floor isnt like finished hardwood. Its roof deck, plywood, carpet.
Old 01-12-2012, 09:45 PM   #5
Rewards Points: 906
In the air moving through the insulation may not be moving into the living space but strips the R-Value from the insulation. That is often times the larger benefit.
If there is not much air movement, I would leave the floors alone.
Old 01-15-2012, 09:58 AM   #6
Remodeling Contractor
Simply put...YES! The cold air entering from soffit vents is creating a convective flow through your insulation reducing the effective R-Value drastically. Hot moves to Cold so even when no wind exists air is moved due to the delta T.
knee wall insulation help david szela Insulation 24 01-13-2012 08:35 PM
Newbie questions on refinishing walkup attic with knee walls FileOpen Insulation 2 11-20-2011 12:31 AM
Zone 6 - Wall Insulation: building out 2x4 walls DoItMyselfToo Building & Construction 15 05-06-2011 09:36 AM
Knee wall w/ soffit vents no ridge vent -- seal soffit vents? tblaz Roofing/Siding 1 04-24-2011 05:12 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
