Insulation Behind Basement Fireplace - Insulation - DIY Chatroom Home Improvement Forum
Old 02-01-2013, 10:33 PM   #1
Insulation behind basement fireplace
Hello,
I am in the process of finishing my basement And want to install a gas fireplace for the main heat source. My 1st floor fireplace is installed in a bump out on the side of the house. This bump out also has a foundation which is where the basement fireplace will go. What type of insulation would be best suitable for the foundation walls behind the fireplace? Foam?
bthom2 is offline   Reply With Quote
Old 02-02-2013, 06:24 AM   #2
Rewards Points: 14,312
Got a picture of where your planning on putting this? Trying picture why in a basement you would use any insulation behind it.
And since foam burns and off gases toxic fumes as it is heated or burns why it would even be used.
Basement Exterior Above Grade Insulation purpasadu Building & Construction 6 02-28-2012 04:42 PM
basement insulation help dp683 Insulation 2 11-14-2011 10:20 AM
Unfinished/Unheated Basement Ceiling Insulation mcusumano Insulation 4 08-31-2011 05:17 PM
Fireplace door insulation? SKINNY General DIY Discussions 3 01-02-2009 04:11 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
