-   Insulation (http://www.diychatroom.com/f103/)
-   -   Insulation behind basement fireplace (http://www.diychatroom.com/f103/insulation-behind-basement-fireplace-170790/)
bthom2 02-01-2013 11:33 PM
Hello,
I am in the process of finishing my basement And want to install a gas fireplace for the main heat source. My 1st floor fireplace is installed in a bump out on the side of the house. This bump out also has a foundation which is where the basement fireplace will go. What type of insulation would be best suitable for the foundation walls behind the fireplace? Foam?
joecaption 02-02-2013 07:24 AM
Got a picture of where your planning on putting this? Trying picture why in a basement you would use any insulation behind it.
And since foam burns and off gases toxic fumes as it is heated or burns why it would even be used.
