Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 04-27-2012, 12:27 PM   #1
insulation basement wall
I have opened up the floor to my bedroom down to the floor joists. The bedroom is on the second floor and plan to add insulation too the space. My basement wall cavity is exposed now and can see there is no insulation in the space between the basement stud wall and the cinder block wall. my basement is a rental so I cant access thru the basement wall. I can access from the top easily, what is the best way to insulate this space from the top?
brettly is offline   Reply With Quote
Old 04-27-2012, 01:58 PM   #2
cortell's Avatar
Um, I don't know any way to effectively install foam board insulation from above. You can drop down the boards into the space, but unless they're firmly adhered to the concrete block, with tight joints in between them, I don't imagine they're going to perform very well, if at all.
cortell is offline   Reply With Quote
Old 04-27-2012, 02:03 PM   #3
Not going to happen.
Old 04-27-2012, 02:11 PM   #4
i suppose you could blow insulation in but that isn't going to work too well either.
itsnotrequired is offline   Reply With Quote
Old 04-27-2012, 03:14 PM   #5
I was thinking of installing rigid foam against the cinder block two layers and stagger the joints trying my best to keep the joints tight. Other possibility fold vapor barrier in half slide folded end into the opening and fill with cellulose or fiberglass insulation.
Old 04-27-2012, 03:21 PM   #6
cortell's Avatar
If you're willing to double up like that, and stagger, and the result is snug...you'll probably be partially, and maybe even sufficiently, successful.
Old 04-28-2012, 08:43 PM   #7
Moderator
The foam board should be air-tight: http://joneakes.com/jons-fixit-database/743
http://www.buildingscience.com/docum...study-analysis
Gary
Clothes taking longer to dry?
Load bearing basement wall? hyunelan2 Building & Construction 9 04-24-2012 12:36 AM
Basement Wall Framing trophywalleye Remodeling 9 01-13-2012 01:15 PM
Townhouse basement insulation benb Building & Construction 0 02-15-2011 10:32 AM
Insulation in basement floor joists and integrated garage speedster1 Building & Construction 3 12-07-2010 06:44 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
