Insulation Of Basement Floating Floor - Insulation - DIY Chatroom Home Improvement Forum
Old 01-20-2013, 10:43 PM   #1
insulation of basement floating floor
We have an unfinished basement with a floating floor construction. The floating wood floor (supported with steel I beams) is located about 24" above the soil since we have expansive soil. A think plastic over the soil, a special paint on the surface of the floor from below and a fan are provided to prevent mold on the wood. The basement is semi-heated but gets very cold in winter. I would like to provide additional insulation (e.g. foam spray) so we could use this space during winters.
Would insulation of the cement walls (about 24" tall mostly below ground level) around the perimeter be more effective or insulation of the whole floor from underneath? Any impact on mold prevention? How thick or what R value? Any other suggestions?
thanks,
Menachem Rafaelof
Superior, Colorado
Last edited by Gary in WA; 01-24-2013 at 08:59 PM. Reason: removed web link per forum rules.
menachem is offline   Reply With Quote
Old 01-21-2013, 12:15 AM   #2
Rewards Points: 14,312
Anyone else having trouble making heads or tails of this post?
Old 01-24-2013, 09:04 PM   #3
Registered User
Rewards Points: 526
With your floating floor over expansive soil, I would insulate the floor joists as such: http://www.buildingscience.com/docum...n-crawlspaces/ and cover with an approved ignition barrier or thermal barrier. Ask your local AHJ which is best for your unique situation; http://www2.iccsafe.org/cs/committee...E_06_64_07.pdf
Gary
Old 01-26-2013, 10:24 PM   #4
Rewards Points: 1,092
i think gary understands it. i'm not familiar w/ what he has enough to comment.
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
Floor joist insulation over basement. rjheard Insulation 2 04-21-2011 11:59 PM
laminate floating floor squeeky, is it normal? gagaliya Flooring 1 10-02-2009 05:27 AM
Installing floating floor over squeaky wood floor- rip it up? (Q3) cee2ski Flooring 1 02-09-2009 06:23 AM
