Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 11-11-2012, 03:05 PM   #1
insulation for basement ceiing sub flooring
Is there any heat or cooling gain through the basement sub floor. j
enviroair is offline   Reply With Quote
Old 11-11-2012, 07:29 PM   #2
Exterior Construction
Windows on Wash's Avatar
Depends on depth, frostline, location, etc.
The reality is there are a host of locations to fix prior to that in most homes.
Old 11-13-2012, 02:33 AM   #3
Heat goes to cold. If one room is colder than the other, heat goes to the colder one. How much heat is lost, and whether or not it is economical to insulate, is all in the numbers. You should at least do an online heat loss calc (free) to get a rough idea of how expensive the cold room is now, and then you can better determine what to do. In general, if you are dumping heat into a cold room that you don't want cold, insulate around the cold room. If you want the room cold, then insulate between the warm and cold room (if it won't get too cold). That is all "imo".
Basement Exterior Above Grade Insulation purpasadu Building & Construction 6 02-28-2012 05:42 PM
Blown in insulation for un-insulated attic Cubey Insulation 10 10-19-2011 08:08 PM
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
How hard to install insulation yourself? techprincesse Building & Construction 26 10-17-2009 10:57 AM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 09:00 PM
