Insulation In Attic And Knee Wall - Insulation - DIY Chatroom Home Improvement Forum
Old 11-09-2012, 01:04 AM   #1
Rewards Points: 79
Insulation in attic and knee wall
I have recently purchased a home and it is a lot cooler up stairs than it is downstairs. The insulation does not look bad in th attic or in the knee wall storage rooms that I have in a room however there is no insulation on the ceiling in any of the room. Is this common to insulate the ceiling? Will this really help keep it warmer upstairs? If so what type of insulation?
Any info or tips would be outstanding!
Thanks!
Zach
mckain87 is offline   Reply With Quote
Old 11-09-2012, 08:24 AM   #2
Rewards Points: 13,300
http://www.dspinspections.com/atticventing.htm
Old 11-10-2012, 03:38 PM   #3
Registered User
Rewards Points: 5,242
Where are you located?
Gary
Building Knee Walls in the Attic Jimmybrp Building & Construction 12 12-23-2011 02:22 PM
Newbie questions on refinishing walkup attic with knee walls FileOpen Insulation 2 11-20-2011 12:31 AM
Converting Attic Knee Wall Space to Insulated Closet gigascott Building & Construction 7 01-20-2011 11:08 AM
attic insulation / knee wall oscarMadison Building & Construction 2 01-19-2010 09:37 PM
attic knee wall insulation improvments truebaca Building & Construction 1 07-07-2007 11:04 AM
