Insulation In Attic - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-11-2012, 10:49 PM   #16
Registered User
Rewards Points: 526
Be sure the cellulose has air movement (not just behind a baffle) above it to dissipate any moisture it gains; http://www.buildingscience.com/docum...+in+flat+attic
Just add f.b. in the tight areas to get a higher R-value per inch, then Roxul as cellulose will slide down (as you can't dense-pack it) leaving weak areas. ADA the ceiling drywall also.
Gary
Attic Insulation Help Needed-What type, etc HandyFrank Building & Construction 9 12-15-2011 01:54 PM
Help with complicated insulation project in attic OhmZoned Insulation 12 11-19-2011 08:49 AM
Attic insulation over old attic floor beffreyj3 Insulation 6 11-18-2011 07:21 AM
Blown in insulation for un-insulated attic Cubey Insulation 10 10-19-2011 07:08 PM
Attic insulation problem Dan77 Building & Construction 7 12-22-2010 02:10 PM
