-   Insulation (http://www.diychatroom.com/f103/)
-   -   Insulation in Attic (http://www.diychatroom.com/f103/insulation-attic-159549/)
BigRedFan 10-09-2012 03:18 PM
Insulation in Attic
1 Attachment(s)
This is my first post so please be nice...We moved into an older home a couple years ago and the previous owners had converted the attic into a master bedroom. It turns out that the insulation job done is absolutely sub par.
We have gotten a few quotes from some "Foam" insulation places and to be honest those prices were shocking. I can not justify paying $2700 to insulate one room.
We are looking into doing it ourselves. I have attached a picture to show the situation since it is easier than describing.
Please let me know your thoughts
jklingel 10-10-2012 01:14 AM
Originally Posted by BigRedFan (Post 1027419)
....so please be nice...
You're kidding, right? :laughing: First, your location and more details of the structure will be helpful. What size boards in the roof? Accessible now? Etc. Fiberglass batts are a poor insulation when left exposed; they are not great to start with. If you must use them, run rigid over the top and tape the seams. On the inside, air seal and use a vapor retarding system. Only use a vapor barrier is code mandates it.
AndyGump 10-10-2012 01:17 AM
J, what is so bad about fiberglass-batt insulation?
Andy.
jklingel 10-10-2012 01:29 AM
Poor quality; some batts have knots, some compressed. Not dense enough to stop internal air currents. R value decreases as it gets colder. Nasty crap to handle, but bugs and vermin love doing what they do (like voiding their bowels and bladders) in it. Does not fit as tight as more rigid stuff, like Roxul. It is OK, but the worst of the batting materials. Dense packed in walls (blown in) it does well. I have 13" of it in my walls, but regret not knowing in 1980 what I know now; it is doing fine, partly because of how it is installed, but something like dense packed cellulose would be far better. That is my take on the stuff.
AndyGump 10-10-2012 02:19 AM
Well, I think fiberglass has its place and uses, in this situation I think he could use both FG and XPS to get the required R value for the Ithaca NY. area (BigRedFan, Cornell University).
The idea about increasing the rafter space from top of knee wall to bottom of ceiling joists is a good one and he could have a lot more insulation in there if he used about 6" of foam with a 1" clearance to the deck for air flow. Then use FG on the knee walls and the ceiling joists.
He can still use R-19 in the walls even though the studs are only 2 x 4s.
Andy.
jklingel 10-10-2012 02:40 AM
Originally Posted by AndyGump (Post 1027917)
Well, I think fiberglass has its place and uses...
Everyone has to make their own call on all this, but I have no use for FG batts unless as a last resort if nothing else is available. We spend too much time doing all this stuff, so why put the worst stuff in? Sometimes you have no choice, though....
Windows on Wash 10-10-2012 07:54 AM
Seal off the floor joist bays with rigid foam, spray foam and seal.
Re-align the fiberglass batts on the knee wall so they are properly spaced out and have the proper depth. Cover the kneewall with a rigid foam (preferably a foil faced ISO of at least 1" and 2" is preferable). Seal all the seams.
Make sure you don't obstruct the venting of the roof with the foam.
Cut and access hole to the small attic. Air seal what you can get to and loose fill blow the attic.
BigRedFan 10-10-2012 10:48 AM
Ok guys I live in Nebraska outside of Omaha. The knee walls are framed with 2x4's and the cieling is 2x6
I am pretty competent with most DIY stuff but know very little about insulation. I have access to behind each side of the knee wall as well as the vaulted spaced through an old ventilation area.
I am at a loss of what to do because I do not want to spend that much $$ on foam, but at the same time would like to improve the tempature control in our master bedroom
BigRedFan 10-10-2012 10:54 AM
I am looking at Roxul online and it seems like I can get a much higher R value than Fiberglass batts for the RValue. What if I did the Roxul and then did some sort of rigid foam on top of that??
Do you think I could fit the higher RValue Roxul in the 2x4 walls?
BigRedFan 10-10-2012 11:30 AM
Ok I think I will tackle the Knee walls before moving onto the Vaulted ceiling area.
I think the plan that I will do is to use the R15 roxul instead of FG batts. On top of that R15 I will use a 2" rigid foam board that will add an additional R10.
That should give me a combined R25 in the walls, well above what I would need for nebraska
Windows on Wash 10-10-2012 08:40 PM
Make sure the foam is rated for exposure in those areas.
If not, it needs to be covered.
BigRedFan 10-10-2012 08:57 PM
how do i tell if it is rated for attic exposure?
also what do i need to do around the existing electrical boxes
http://www.homedepot.com/Building-Ma...1#.UHYZ_BRGJ5Q
something like that is what i had in mind
Windows on Wash 10-10-2012 10:00 PM
The foam will have to have a minimum of a foil facing.
Around the electrical boxes, spray foam.
They shouldn't stick out past the outer edge of the stud wall anyway.
Gary in WA 10-11-2012 12:20 AM
Roxul is way better than fiberglass in the wall cavity. Foam board (which stops thermal bridging of the studs and acts as an air barrier) or house wrap on the attic side is good. Don't forget to air block under the knee wall (stop air movement in the rooms floor/ceiling space) and over it, leaving an air space to vent it yet protect the slope insulation from air. ADA the drywall on the conditioned side: http://www.buildingscience.com/docum...wall-approach/
Use baffles or foil-faced polyiso board at the soffit inlet vents to prevent wind-washing of the knee-wall attic insulation, air seal the wiring/plumbing holes and can lights, weatherstrip the access door and insulate it: http://www.buildingscience.com/docum...ation-packages
Caulk/canned foam the drywall/plate joints before insulating floor, "A", "D" (Air leakage paths): http://www.conservationtechnology.co...eakagePathways
Caulk the bottom plate/floor joint against air leakage, as per code minimum, #6: http://publicecodes.cyberregs.com/ic...002_par021.htm
Use DIY f.b. baffles rather than plastic or foam manufactured ones because the floor cavity insulation could touch the roof sheathing (on both sides of the baffle) for thermal conduction and "night sky radiation" over the exterior wall, compromising the R-value of the insulation; http://www.buildingscience.com/docum...n-roof-venting
How are you planning the sloped ceiling insulation?
Gary
BigRedFan 10-11-2012 10:13 AM
Gary
Slopped ceiling I was going to blow in some loose fill cellulose
