Insulation around skylight tunnel
24K views 24 replies 4 participants last post by  Gary in WA
I am curious what everyone recommends for insulating skylight tunnel. Currently there is 2x4 frame and the builder is proposing R21 batt but not sure how it will stay in place. is it advisable to use small R 15 and perhaps put foam board around the exterior frame?
Your location is helpful as well.....
Gary
#5 ·
Thank you and my apologies for not making myself clearer. I am located in Chicago so I am not sure what R value is required for "knee wall" areas such as this. The skylight is located in unconditioned attic space. This isn't actual picture of our house but very close to what we have:
#6 ·
One issue I see is 2x4 construction with the tunnel. Seems like there won't be enough room for both rigid foam... As mentioned previously, I think my installer was going to just put R21 with some insulation just sticking out. What sort of air barrier would you guys recommend? Plywood sheathing, Tyvek?
#7 ·
Insulated between the studs with unfaced R13 batts (or better yet something like Roxul because it won't sluff or fall down over time.
Install rigid foam over the studs to thermally uncouple them from the attic (minimum layer or 1" for complete thermal break). I would shoot for 2" as they get hot that far up.
Make sure the foam is covered or code compliant to be exposed.
#8 ·
If you go with the R-21 batt and no foamboard (taped and air-sealed), use a asphalt-coated paper faced batt required for your Zone 5: http://publicecodes.citation.com/icod/irc/2009/icod_irc_2009_11_sec001_par001.htm
R-38 is required in ceilings there; http://publicecodes.citation.com/icod/irc/2009/icod_irc_2009_11_sec002.htm
The skylight shaft is similar to a ceiling as the rising warm air collects there (add to that the solar gain...). Best to insulate the side walls well to cover any major heat loss (more than required wall insulation). ADA the drywall also: http://www.buildingscience.com/documents/information-sheets/air-barriers-airtight-drywall-approach/
With the low R-value the skylight itself provides, you need all the help you can get.
Gary
#9 · (Edited)
Hi Gary,
Thank you so much for the additional information! I will definitely push for as much of ADA as possible. A few questions:
1. I am still a bit confused about how much R value is really required under the code for tunnel or knee wall - is it R38 or R21 for zone 5 (Chicago)?
2. I would love to see R38 on the tunnel but just not sure how feasible that would be. I can ask them to add another layer of 2x6 frame to allow total of 10" to allow R38 sticking out 2".
3. I am most curious whether using thicker batt which sticks out is better than using thinner lower R value batt with some sheathing.
4. He is using Kraft backed batt - is this the same as asphalt-coated? or do I need to specifically request?
Sorry for so many questions and thanks for everyone's help!
Gary
#10 ·
The shaft is considered wall (more like kneewall) as compared to attic floor by most inspectors.
Use rigid foam. It works far better and is not susceptible to wind wash and other issues that fiberglass suffers from.
The money spent in additional framing will easily be more expensive than just using foam board.
Kraft paper is more proper in this case as compared to a PSK fiberglass.
#11 ·
It is a side wall, so the minimum insulation for walls is required (my point was the great heat loss in the shaft/hole in the ceiling-plane), with a vapor retarder. Code also accepts foam board exterior of the cavity insulation in which case the vapor retarder is omitted. The dew-point of the cavity changes because the foam board keeps the wall warmer.
Use the faced as you said (without the foam board), though a high density batt is much better at stopping convective loops within low density batt;
"R-13 HD at 1.0# density
R-19 at 0.55# density
R-21 HD at 0.90# density
R-30 at 0.57# density
R-38 at 0.53# density
All the ones (low density) listed without a HD (High Density) will have inherent convective loops in a wall or attic floor installation.
Taken from my info collected and posted here: http://www.diychatroom.com/f98/biggest-loser-fiberglass-insulation-90438/
The foam board is much better as it stops air movement degrading f.g. batts; http://www.aecb.net/PDFs/Impact_of_thermal_bypass.pdf
The paper facing should be asphalt coated to meet the vapor retarder (Class 2) requirements per code:http://publicecodes.citation.com/icod/irc/2009/icod_irc_2009_6_sec001_par003.htm
http://publicecodes.citation.com/icod/irc/2009/icod_irc_2009_6_sec001_par005.htm
OR, add R-5 foam board (that stops convective looping) with 2x4 framing:http://publicecodes.citation.com/icod/irc/2009/icod_irc_2009_6_sec001_par004.htm
The dew-point changes: http://www.greenbuildingadvisor.com/blogs/dept/musings/are-dew-point-calculations-really-necessary
The science behind it: http://www.buildingscience.com/documents/reports/rr-0412-insulations-sheathings-and-vapor-retarders
If no f.b. and only Kraft-paper faced, one type has the coating and one doesn't (paper alone won't stop moisture). Use the coated one as it has variable permeability: http://www.buildingscience.com/documents/reports/rr-0004-air-barriers-vs-vapor-barriers
Without the f.b., at least add a housewrap to the shaft on the attic side, over the f.g.- like Tyvek or similar permeability to let the moisture out from any air gaps in the ADA or regular diffusion (minimal).
Gary
#12 · (Edited)
Thank you! Great info but I am still dazed by all of the info... If you don't mind can I confirm a few takeaways from this post?
1. If I decide to use foam board, do I not use unfaced batt of R13 for 2x4 wall?
2. R13 + R5 = R18 (foam board) < R21 ... I guess eliminating air movement is more important than just R value for this application? I just want to ensure no condensation along the shaft and to keep the cold/heat out as much as possible.
3. If I decide to go with coated Kraft paper batt (R21) which sticks out a bit, can I still wrap it with Tyvek? I feel as though I might be "squeezing" the insulation while wrapping/taping...
Thank you
#16 ·
1. If I decide to use foam board, do I not use unfaced batt of R13 for 2x4 wall?---- correct.
2. R13 + R5 = R18 (foam board) < R21 ... I guess eliminating air movement is more important than just R value for this application? ----- correct. I just want to ensure no condensation along the shaft and to keep the cold/heat out as much as possible.------ the f.b. will warm the cavity condensation free.
3. If I decide to go with coated Kraft paper batt (R21) which sticks out a bit, can I still wrap it with Tyvek? I feel as though I might be "squeezing" the insulation while wrapping/taping...----- the minimal compressing, if you don't wrap it snug, will hardly lose more R-value than you are gaining by preventing wind-washing of the batts.
Thank you
My answers are in red, above.
Gary
P.S. FYI to all members; when a poster asks a question/s with a "quote" present from a previous post, proper forum etiquette is to wait on the member quoted to answer first, then cover anything pertainent with your answer. This is the primary use of the "quote" button/box- to direct it back to the original poster. Good manners are important everywhere, even on forums, otherwise it comes off as rude.
#13 ·
If you go with foam, used unfaced fiberglass.
If you are worried about condensation, foam board is the only way to go. It breaks up the thermal bridging of the studs and keeps them much closer to room temp and therefore away from dew point.
Skip the R21 batt idea and use the foam. Just check the codes for exposed foams and once you have one layer on it, I would just as soon double it up.
#21 ·
Reactions: sbkim
#22 ·
Quick update. I have a good news and sort of bad news. Good news is builder agreed to increase framing to allow R21 (I am sure he will find a way to charge me for this) but the bad news is that insulation guy is saying I need vapor barrier on the warm side even with the foam board?! Is this accurate? I thought unfaced was recommended.
Thanks again!
#23 ·
He needs to reboot..... In my post #11, under "are dew-point calcs..." last paragraph of link.http://www.greenbuildingadvisor.com/blogs/dept/musings/are-dew-point-calculations-really-necessary
Put 2" f.b. and latex paint inside, your f.g.batts, you'll meet code requirements: http://www.buildingscience.com/docu...ulating-sheathing-vapor-retarder-requirements
Further reading for him to up-date his databases: http://www.ecodes.biz/ecodes_suppor...ational Energy Conservation Code_Resource.pdf
Gary
#25 ·
