Insulation Around Old Brick Fireplace - Insulation - DIY Chatroom Home Improvement Forum
Old 05-04-2014, 09:16 PM   #1
Insulation around old brick fireplace
Hello all,
I have a quick question regarding insulation around my fireplace.
I just tore down all the stone that was covering my fireplace and I plan on installing some metal studs and concrete backerboard.
What kind of insulation can I put around the brick fireplace particularly the top of the firebox. Is standard fiberglass ok? There was a little fiberglass in it before. See attachement.
dannyn is offline   Reply With Quote
Old 05-04-2014, 09:35 PM   #2
Rewards Points: 6,652
Nothing at this point. You need to bring in a Chimney cleaner to inspect if it is even worth salvaging. You may not like their inspection report.
Personally I would not start this without money and a plan.
The Following User Says Thank You to gregzoll For This Useful Post:
Windows on Wash (05-07-2014)
Old 05-04-2014, 09:37 PM   #3
What do you mean? There's nothing wrong with it. I just removed the stone that was covering it.
Old 05-05-2014, 12:00 AM   #4
That is not what the picture shows. That fireplace is beyond its time.
Old 05-05-2014, 12:05 AM   #5
No. The Fireplace Is Fine. My Question was Regarding Insulation...
Old 05-05-2014, 12:23 AM   #6
Nothing you can do at this point with insulation. You need to have that fireplace looked at by someone. The whole thing speaks volumes of not being properly built from the beginning.
How old is this house that the unit is in?
Old 05-05-2014, 07:23 AM   #7
Concrete & Masonry
Rewards Points: 470
Don't mind Gregzoll, he has no idea what he's talking about, and aparently has never seen what's behind a conventional FP veneer. That's fairly typical construction for that era.
I would have some concern about the framing being that close to the FP & chimney though, current code calls for 2" minimum clearance on interior spaces, such as this......
jomama45 is online now   Reply With Quote
Old 05-05-2014, 12:38 PM   #8
Thanks jomama45.
The framing is the original framing. I didn't add anything to it. There is maybe a 1" space between the frame and chimmey. I am planning on adding some metal studs so that I can add the concrete backerboards.
Should I just not add insulation since there was nothing in there in the first place?
Old 05-07-2014, 11:43 AM   #9
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 880
Not sure it looks that great to me either but I am not a mason. I can't imagine that I would benefit from some tucking of the mortar joints and general spit and polish.
In terms of the insulation, Rock Wool is your best bet here.
Old 05-07-2014, 07:31 PM   #10
Rewards Points: 332
Send a message via Yahoo to curtd
Where i work they use ceramic insulation in the 1700 degree furnaces
curtd is offline   Reply With Quote
Brick over fireplace clean-out diystephen Concrete, Stone & Masonry 1 02-18-2014 01:51 PM
Looking for expert advice for adding insulation under a gas fireplace MileHigh80228 Insulation 14 12-11-2012 02:12 PM
Brick Fireplace - how to Tile over it? cody21 Concrete, Stone & Masonry 4 10-21-2012 10:52 AM
Redoing brick on fireplace hellothere123 General DIY Discussions 0 06-29-2011 11:34 PM
Drywall a Brick Fireplace schw1927 General DIY Discussions 1 01-26-2011 04:12 PM
