-   Insulation (http://www.diychatroom.com/f103/)
-   -   Insulation around old brick fireplace (http://www.diychatroom.com/f103/insulation-around-old-brick-fireplace-200314/)
dannyn 05-04-2014 09:16 PM
1 Attachment(s)
Hello all,
I have a quick question regarding insulation around my fireplace.
I just tore down all the stone that was covering my fireplace and I plan on installing some metal studs and concrete backerboard.
What kind of insulation can I put around the brick fireplace particularly the top of the firebox. Is standard fiberglass ok? There was a little fiberglass in it before. See attachement.
gregzoll 05-04-2014 09:35 PM
Nothing at this point. You need to bring in a Chimney cleaner to inspect if it is even worth salvaging. You may not like their inspection report.
Personally I would not start this without money and a plan.
dannyn 05-04-2014 09:37 PM
What do you mean? There's nothing wrong with it. I just removed the stone that was covering it.
gregzoll 05-05-2014 12:00 AM
That is not what the picture shows. That fireplace is beyond its time.
dannyn 05-05-2014 12:05 AM
No. The Fireplace Is Fine. My Question was Regarding Insulation...
gregzoll 05-05-2014 12:23 AM
Nothing you can do at this point with insulation. You need to have that fireplace looked at by someone. The whole thing speaks volumes of not being properly built from the beginning.
How old is this house that the unit is in?
jomama45 05-05-2014 07:23 AM
Don't mind Gregzoll, he has no idea what he's talking about, and aparently has never seen what's behind a conventional FP veneer. That's fairly typical construction for that era.
I would have some concern about the framing being that close to the FP & chimney though, current code calls for 2" minimum clearance on interior spaces, such as this......
dannyn 05-05-2014 12:38 PM
Thanks jomama45.
The framing is the original framing. I didn't add anything to it. There is maybe a 1" space between the frame and chimmey. I am planning on adding some metal studs so that I can add the concrete backerboards.
Should I just not add insulation since there was nothing in there in the first place?
Windows on Wash 05-07-2014 11:43 AM
Not sure it looks that great to me either but I am not a mason. I can't imagine that I would benefit from some tucking of the mortar joints and general spit and polish.
In terms of the insulation, Rock Wool is your best bet here.
curtd 05-07-2014 07:31 PM
Where i work they use ceramic insulation in the 1700 degree furnaces
