Insulation Around Electric Fireplace - Insulation - DIY Chatroom Home Improvement Forum
Old 10-24-2011, 11:34 AM   #1
Insulation around electric fireplace
I recently installed an electric fireplace in my den. the back part of the fireplace sticks out into the garage which is uninsulated. i built a 2x4 frame covered by wonderboard around the back portion of the fireplace. My question is, what kind of insulation can i use on the inside of the box when i seal off the outside of the box in the garage. I have already contacted the manufacturer of the fireplace and they could not give me a specific answer. They did say that there is a sensor that shuts it down if it gets over 130 degrees fahrenheit. i already read that the rigid foam insulation does not work. Any thoughts?
tile4fun is offline   Reply With Quote
Old 10-25-2011, 08:13 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,784
Rockwool is good in this case.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Attic insulation problem Dan77 Building & Construction 7 12-22-2010 03:10 PM
Electric fireplace Red Squirrel Electrical 8 09-14-2009 04:30 PM
Old home insulation woes nowwhatnapster Building & Construction 15 11-03-2008 12:59 AM
Ventless gas fireplace vs. Home furance Dougit General DIY Discussions 6 01-05-2008 05:01 PM
