Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 06-15-2012, 09:38 AM   #1
insulation and advanced framing
Zone 2, hot and humid---
I am thinking about building a 'shed', 16' x 24', 2 x4 walls, 24" OC, and want it to be energy efficient. (it might convert to an office space or MIL suite at some point in the future so I would want to get the details correct up front, plus i like learning about this stuff...)
So, I ~think~ from reading the tables, and please correct this idea if it is wrong, that I can frame the walls 24" OC and use 2 x 4s since it is single story with a simple roof.
If I pay the extra for 2 x 6 walls will the insulation gain(assuming i follow the techniques for a tight envelope) be worth it in my climate?
I would probably use a mini-split for hvac, or maybe a through the wall unit, if that matters.
Comments are appreciated!
7echo is offline   Reply With Quote
Old 06-17-2012, 10:20 AM   #2
Exterior Construction
Windows on Wash's Avatar
Going to 2x6 for insulation purposes is not really worth it.
I prefer 2x6 structure but not for the insulation value.
Look up rigid foam to the exterior and go that route.
Old 06-17-2012, 10:44 AM   #3
i think that is what i am going to do.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Attic insulation baltimorebob Insulation 11 01-02-2012 01:04 AM
Rafter framing code question anesthes Building & Construction 32 01-21-2011 11:43 PM
Wall insulation techniques - 2x6 vs double 2x4 vs foamboard sheathing dwoloz Building & Construction 6 01-12-2011 10:58 PM
Advanced framing or conventional? dwoloz Building & Construction 21 12-07-2010 02:02 AM
Framing a garage ceiling bobber Carpentry 1 11-24-2009 01:01 PM
