Insulation Above A Garage? - Insulation - DIY Chatroom Home Improvement Forum
Old 09-13-2011, 11:09 PM   #1
Insulation above a garage?
I have a ranch style house in the suburbs of Chicago with a three car garage. The attic space above the garage is not insulated. The garage gets very hot in the summer & very cold in the winter. The garage doors themselves are insulated & all of the garage walls are insulated. My question is will insulation help these issues & more importantly, what type of insulation should I use? Ex. Faced, unfaced, blown in fiberglass or cellulose only etc? Don't know if a faced batt can be installed after the fact?
Mjsunde is offline   Reply With Quote
Old 09-14-2011, 12:49 AM   #2
Not a Noob or Boob
Blown in would be your best option, IMO. You can get a great R value for the price. You will def feel a difference!
What burb? I am in Naperville!
Rob1975 is offline   Reply With Quote
Old 09-14-2011, 06:20 AM   #3
It should help with the heat in summer, but it will still get cold in winter. I assume this ia a detached garage??
Old 09-14-2011, 08:28 AM   #4
Not a Noob or Boob
If it keeps the heat out it will also keep the heat in.
Old 09-14-2011, 10:08 AM   #5
It's an attached garage & I live in Huntley, IL! So you think blown in is the way to go?
Old 09-14-2011, 12:30 PM   #6
Not a Noob or Boob
That's my vote. The only thing better would be spray foam, but I am not a fan. Once it is in, it is there to stay. Any remodeling or upgrading is a big pain. Also if there is no vapor barrier between the foam and drywall, replacing drywall becomes a nightmare. With a vapor barrier you can just remove the drywall, foam is on the other side of the VB and replace drywall as needed.
Old 09-14-2011, 12:31 PM   #7
Ole Wood Worker
BigJim's Avatar
Rewards Points: 754
If it is an attached garage you may want to consider sprayed foam to seal your home from the gas and carbon monoxide fumes your cars and other things can produce.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
Rob1975 (09-14-2011)
Old 09-14-2011, 12:40 PM   #8
Not a Noob or Boob
Anything you can do to keep the gases from the garage entering the house is a good idea. But I think if you are not going to foam the entire garage, the ceiling isn't going to prevent much from entering the house. If gases do reach the attic, and you have proper attic ventilation, the gases will vent out the roof.
Seals on garage doors and any cracks in the drywall are the areas that gases are most likely to penetrate the home. Here is a great article on toxic gases in the garage.
http://garages.about.com/od/building...ir_quality.htm
The Following User Says Thank You to Rob1975 For This Useful Post:
BigJim (09-14-2011)
Old 09-14-2011, 01:29 PM   #9
Rewards Points: 5,336
You should also vent the attic space above. Any trapped super heated air will drive throught the insulation and add heat to the garage space. Adding insulation and a venting system will deal with the issue.
Ron
B. Franklin 1759
Old 09-14-2011, 01:33 PM   #10
Not a Noob or Boob
Good call, make sure it is properly vented.
Old 09-14-2011, 10:00 PM   #11
Thanks everyone for all the input-it is greatly appreciated!
Garage Ceiling Insulation Help PyroG Building & Construction 14 02-16-2010 08:17 AM
Garage Insulation Jim Hart Building & Construction 3 11-12-2009 07:44 AM
Garage Door Insulation PaliBob Building & Construction 4 03-27-2009 03:05 PM
Insulation questions for new detached garage mpt1123 Building & Construction 2 03-01-2009 08:18 AM
Detached Garage Insulation Unregistered Building & Construction 2 02-28-2004 03:31 PM
