Insulation 2 - Insulation - DIY Chatroom Home Improvement Forum
Old 11-17-2011, 04:13 PM   #1
Question
insulation 2
I've read all I could find for my particular situation and got a couple of replies (thanks guys) and I know enuff now to re-think the whole concept!
Situation is: I have what appears to be rock wool laying in my attic varying in depth from 0-5''. house is 1962, well built, I live in Eastern Oregon 8' of snow and not much below 0 temp. and it is generally quite dry.
I'd like to add insulation to the attic, there isn't but 4' of headspace at the highest point and you can barely make it to within 10' of the edge of the house.
I don't want to take all that rock wool out and want to add insulation.
should I forget the vapor barrier issue and just add fibreglass insulation between the ceiling joists? (not the roof joists)
Thanks, Jim,
jimrr is offline   Reply With Quote
Old 11-17-2011, 04:23 PM   #2
Don't WANNA do it myself
mnp13's Avatar
Rewards Points: 512
It would probably be a lot easier to blow in cellulose over all of it.
mnp13 is offline   Reply With Quote
Old 11-18-2011, 07:14 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,258
How is the roof currently vented?
Old 11-18-2011, 09:21 AM   #4
Roof has 12 X 14'' screened vent each end and eves have nearly full length 1.5'' screen. (length of house ....50') I am told I need to enlarge these vents although with enough insulation up there I don't know if this would be necessary.
Old 11-18-2011, 09:55 AM   #5
Air Seal the attic first, then insulate.
If the soffits are not vented, you can blow the insulation right down to the eaves.
Old 11-19-2011, 10:51 AM   #6
Wink
THANKS FOR THE HELP ALL.
Jim,
Attic insulation over old attic floor beffreyj3 Insulation 6 11-18-2011 07:21 AM
Which insulation? Photos attached of room homiefb Insulation 1 08-16-2011 05:44 AM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
Has anyone used Green Fiber blown in insulation? pomelo Building & Construction 7 02-10-2010 07:17 AM
