Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 10-16-2012, 08:17 PM   #1
insulation
I bought R30 unfaced insulation ( it was so cheap). I want to use it for my attic & the ceiling of my garage. How can i face the unfaced insulation? Can i use the paper for the roofing as a vapor barrier for the unfaced insulation?
zakragab is offline   Reply With Quote
Old 10-17-2012, 01:56 AM   #2
Moderator
insulation
Welcome to the forums!
Where are you located?
Gary
Clothes taking longer to dry?
Gary in WA is online now   Reply With Quote
Old 10-17-2012, 02:48 AM   #3
insulation
Worry more about air sealing. I'd suggest you read on buildingscience.com and see if a vapor barrier (as opposed to a vapor retarder) is even recommended for your location (probably not, unless you are in an extreme climate).
Insulation question for vaulted home Talgonadia Insulation 3 08-22-2012 07:06 AM
?'s about foil-faced "bubble wrap" insulation badger73 Insulation 5 06-25-2012 06:09 AM
Several Insulation Quotes, Big Decisions to make knotquiteawake Insulation 2 05-04-2012 12:16 PM
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
Rafter Vents and Insulation nofx1981 Roofing 15 03-10-2010 09:14 PM
