Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 10-09-2012, 11:17 AM   #1
insulation
I have a 2x6 beamed ceiling holding up a new metal roof. I want to keep part of the beams uncovered. do I need to vent above the insulation to keep out moisture? We are located in northern NM.
sue4254 is offline   Reply With Quote
Old 10-10-2012, 04:09 AM   #2
An old Tradesmen
Rewards Points: 7,408
Moved to insulation forum.
Old 10-10-2012, 06:55 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,760
You would need to vent in this case to let the moisture out, not keep the moisture from getting in.
Picture will help in this case but it sounds like the roof is going to need to be vented regardless. Do you have soffits on the roof?
Insulation question for vaulted home Talgonadia Insulation 3 08-22-2012 06:06 AM
?'s about foil-faced "bubble wrap" insulation badger73 Insulation 5 06-25-2012 05:09 AM
Several Insulation Quotes, Big Decisions to make knotquiteawake Insulation 2 05-04-2012 11:16 AM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
