-   Insulation (http://www.diychatroom.com/f103/)
-   -   insulation (http://www.diychatroom.com/f103/insulation-156636/)
kandi 09-12-2012 06:23 PM
insulation
laying insulation over wiring in attic
gregzoll 09-12-2012 06:25 PM
Okay.
AngelArs 09-12-2012 06:34 PM
I hope that wiring isn't K&T.
Insulation around K&T is a big no-no
:whistling2:
joecaption 09-12-2012 06:40 PM
So what's the question?
AngelArs 09-12-2012 07:03 PM
I think she thinks she's on twitter :eek: :laughing:
DangerMouse 09-12-2012 07:43 PM
Once again, this is a forum, not google, populated by REAL people willing to answer QUESTIONS when asked. Posts like yours will either go unanswered or our members will be irked by your lack of common sense and reply with rude or silly answers. If you have a question, please post it as such.
Thank you
DM
Fix'n it 09-12-2012 08:55 PM
:whistling2:
my attic is full of both. has been for decades. i have yet to see a problem with it. and i am still using much of it, for now.
AngelArs 09-12-2012 09:29 PM
Consider yourself lucky. You might want to do yourself a favor and revisit the issue. It's a well known fire problem :furious: K&T is an air insulated system and requires surrounding air to keep it cool. Most insulation packaging warns about this. Most insurance companies won't pay out if its discovered that's how the fire started. Here's a quick reference talking about it.
K&T is an air insulated system and becomes a fire hazard when it is buried in house insulation.
Fix'n it 09-13-2012 08:25 PM
i know all about it. and i am doing something about it, 1 room at a time. but the K&t in this house is pretty high quality. the sheathing is in darned good shape. and the wire is heavy gauge.
gregzoll 09-13-2012 08:29 PM
Industrial grade huh. Of course, why can't they make stuff to last like they did back in the day, when unions were not involved, and there was pride in workmanship.
AngelArs 09-14-2012 09:59 AM
I'm glad that you're aware of this matter and most importantly, that you're taking steps to correct it. Just to clarify, this has nothing to do with the condition of the K&T, or it's gauge. This is purely about the wire 'suffocating' under insulation (there is no surrounding air to cool it). I know it's a pain in the butt to replace it (I'm in the process of replacing mine too) with modern day wiring, but on the bright side you only have to do this once:thumbsup:
Fix'n it 09-15-2012 08:43 AM
actually, no, its not.
its about the "load" on that wire. when there is too many things running on that wire, the wire gets hot. when the wire gets very hot, it makes things around it very hot. whether or not a fire starts because of this, depends on how close and what type of combustibles are around that wire.
sure, if there is no "suffocation" going on, chances of a fire are lower.
if the wire is not "overloaded", then a fire will not happen.
AngelArs 09-15-2012 12:01 PM
Tell that to the United States National Electric Code (NEC). Your reasoning may be true in a perfect world but that discounts the whole purpose for insulation, which is to isolate heat in or out, in this case inside the wiring jacket made out of old flammable cotton cloth. No one here is talking about over loading the wires capacity. The whole reason why K&T was suspended in air was so that it could dissipate heat. Not necessarily heat from a overloaded circuit, but just normal dally heat from normal electric current. When you take away that heatsink (in this case the air) and surround the wire with insulation, the knob and tube wires are no longer suspended in air, and naturally will become hotter than intended. Anyway I'm not here to debate the facts which should seem obvious. I was only trying to help. Once a fire starts you can debate your opinion with it, and the insurance company. Speaking of the NEC, it doesn't appear that you were aware that the United States National Electric Code (NEC) section 324-4, actually forbids the use of loose, blown-in, or expanding foam insulation over Knob and Tube wiring. I wonder why? :whistling2:
Gary in WA 09-15-2012 10:23 PM
Any other questions, kandi?
Gary
