Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 01-02-2012, 12:43 AM   #1
Insulation
Need help with foam insulation on my home. I was told that the foam is used to seal every area of attic so there will be no air flow. I have vents, is it ok that they will have no use anymore?
Michael7777 is offline   Reply With Quote
Old 01-02-2012, 06:43 AM   #2
the Musigician
DangerMouse's Avatar
Insulation
If you mean soffit vents, you do not seal those with foam or cellulose. They should have baffles to allow air flow through the attic, but not down below to the home.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 01-02-2012, 01:30 PM   #3
Insulation
I was told that they seal everything in the attic to not allow humidity to come in . It's acts as a cooler in the attic. He said if you allow the moisture to get in that it makes everything worse
Old 01-02-2012, 03:01 PM   #4
the Musigician
Insulation
More information needed.
DM
Old 01-02-2012, 03:29 PM   #5
Insulation
I live in Florida .
Old 01-02-2012, 03:40 PM   #6
the Musigician
Insulation
Perhaps we should start with "who told you this?" And maybe roof type/pitch?
Photos are always worth a thousand words here.
DM
Old 01-02-2012, 03:58 PM   #7
Insulation
Both insulation companies who came out to give me an estimate.
Old 01-02-2012, 04:07 PM   #8
Insulation
I have a tile roof.
Old 01-02-2012, 04:52 PM   #9
the Musigician
Insulation
I can move this to roofing if you wish, the guys there can help you better than I can with this.
DM
Old 01-02-2012, 05:49 PM   #10
Moderator
Insulation
1. So you must have your HVAC in the attic, with all the ducting, is that correct?
2. How thick a layer are we talking about?
3. Will they add fibrous insulation after that?
4. Where will they be spraying? Joists, rafters, ?
Gary
Clothes taking longer to dry?
Old 01-02-2012, 05:49 PM   #11
Insulation
Ok. Thank you
Old 01-02-2012, 05:57 PM   #12
Insulation
The house is CBS construction. I live in Florida. They are apparently going to spray the tie beams above the ceiling and the roof. The spray foam will be about 5 inches thick which will be a little bit higher than what the 2 by 4 is
Old 01-02-2012, 05:57 PM   #13
Insulation
No fibrous material after
Old 01-02-2012, 05:58 PM   #14
Insulation
Hvac?? There are ducts in the attic . It's a one story home
Old 01-02-2012, 06:19 PM   #15
Moderator
Insulation
Good to go: http://www.joelstiburek.com/topten/south.htm
http://www.buildingscience.com/docum...d-roof-systems
http://best2.thebestconference.org/pdfs/040_EE11-3.pdf
They all say the same thing, just a different slant. The last one is the paper the second one is from.
And the IRC: "The IRC also prohibits a vapor retarder on the attic floor of conditioned attics so that any moisture that may build up in the attic can dissipate into the house. If wood shingles or shakes are used, a ¼-inch air gap must be left above the roof sheathing, but below the shingles or shakes and roofing felt" Read the whole article: http://resourcecenter.pnl.gov/cocoon...r/article/1520
Gary
Attic insulation over old attic floor beffreyj3 Insulation 6 11-18-2011 08:21 AM
Which insulation? Photos attached of room homiefb Insulation 1 08-16-2011 06:44 AM
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
Rafter Vents and Insulation nofx1981 Roofing 15 03-10-2010 09:14 PM
Has anyone used Green Fiber blown in insulation? pomelo Building & Construction 7 02-10-2010 08:17 AM
