Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 10-15-2011, 10:15 PM   #1
Which insulation?
Blown in or foam in wall for a hallow wall?
Mikew651 is offline   Reply With Quote
Old 10-15-2011, 10:43 PM   #2
Msradell's Avatar
Which insulation?
The foam cost more initially will probably also perform better. It will fill the cavity better, will help prevent air infiltration and won't settle over time like conventional blown in insulation will. It's definitely a better option if you can handle the additional cost.
Msradell is offline   Reply With Quote
Old 10-16-2011, 09:30 AM   #3
Exterior Construction
Windows on Wash's Avatar
Which insulation?
You are speaking of retrofit and not new construction I take it?
Foam will perform better over time but it will be more expensive by order of magnitude depending on where you get it priced from.
Which insulation? Photos attached of room homiefb Insulation 1 08-16-2011 06:44 AM
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
Rafter Vents and Insulation nofx1981 Roofing 15 03-10-2010 09:14 PM
Has anyone used Green Fiber blown in insulation? pomelo Building & Construction 7 02-10-2010 08:17 AM
super insulation retrofit with rigid insulation hostaking Building & Construction 5 01-07-2009 11:23 AM
