Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 04-21-2011, 01:25 PM   #1
insulation
what is faced and unfaced insulation
shawn35 is offline   Reply With Quote
Old 04-21-2011, 01:27 PM   #2
Residential Remodeler
insulation
Faced insulation has a vapor barrier facing the heated area. It is usually faced with plastic or paper - i.e. Kraft faced.
Unfaced insulation, is insulation without a vapor barrier.
CookeCarpentry is offline   Reply With Quote
Old 04-21-2011, 01:34 PM   #3
insulation
Hey shawn35,
Faced insulation and unfaced insulation is a fiberglass insulation that comes in different thicknesses.
Faced means that one side has a paper backing on it that acts as a vapor barrier and makes it easy to install vertically.
Unfaced insulation is just fiberglass and is often used in attics and in between floors.
I attached a picture.-Gregg
gotogregg is offline   Reply With Quote
Old 04-23-2011, 11:48 PM   #4
Moderator
insulation
One has a vapor retarder, one doesn't. All the plastic foam boards come either faced or unfaced. Also get denim batts, rock wool, etc. that are better than fiberglass, my least favorite; The "biggest loser" in fiberglass insulation....
Fiberglass batts are 15" and 23", made to stand alone, slightly compressed in the stud cavity, not requiring stapling the paper facing for an effective moisture retarder. All of the faced ones with plastic or paper should not be used below grade in most of the U.S., where are you located? And, welcome to the forum!
Gary
Clothes taking longer to dry?
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
blow in insulation question Cool user name Remodeling 4 12-31-2010 12:24 AM
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 03:33 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
