Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 04-20-2011, 12:38 PM   #1
insulation
HOW TO insulate deck floor no acess from below, to make a four season room gas fireplace for heat.
B MCLEAN is offline   Reply With Quote
Old 04-20-2011, 01:33 PM   #2
the Musigician
DangerMouse's Avatar
Very difficult, I'd say.
Have you considered an insulated flooring, such as cork?
It's soft and warm and it wears well.
DM
Old 04-20-2011, 01:50 PM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 712
If you are turning a deck into a four season room, you are essentially "adding-on" to your home. I would suggest that you check with your local building dept for proper codes on this project.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
blow in insulation question Cool user name Remodeling 4 12-31-2010 12:24 AM
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 03:33 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
