Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 12-07-2012, 08:04 AM   #1
Insulating a Vinyl Garage Door
I have a vinyl type product garage door. 4 panels that are straight open and across, 9 feet long and 16 inches wide with no edges to tuck in any blanket type insulation similar to what is in the Owens Corning Kit. I came across a product at my local home depot called "Reflectix".
1. Would this product work for my door?
2. If it will help warm up the garage a bit should I leave a pocket of air behind or attach it directly against the door and secure with the tape they also sell at home depot for this product?
Thanks for any tips? I can take a pic if necessary.
Paul
06Honda is offline   Reply With Quote
Old 12-07-2012, 08:17 AM   #2
I just use 1" blue foam attached with constrution adhesive made just for foam.
Old 12-07-2012, 04:27 PM   #3
Update:
I ended up using a product today called "Ayr-Foil", fairly easy installation with an air pocket on each panel. Way brighter in the garage thats for sure. May take a day or so to see if the temp is warmer.
Old 12-07-2012, 07:59 PM   #4
Moderator
Check with your local AHJ, blue foam board requires covering for fire-stopping, the foil-faced may not. Though it may require positive fastening, other than adhesive.
Gary
Clothes taking longer to dry?
Garage Door Assistance dukes32 General Discussion 2 06-15-2011 01:11 PM
Do I have a Fire Rating Issues with Attached Garage Perry401 Building & Construction 4 04-26-2011 12:58 AM
Garage Door Question javan Building & Construction 4 04-25-2011 07:52 AM
graffiti on vinyl garage door RMCarner Painting 1 08-11-2010 07:45 AM
Garage Door Install Opinions detailedEye Building & Construction 4 03-31-2010 11:15 PM
